gunnerthesnowman
Hi all , maybe wrong forum, but maybe someone will know , had to drop trans to do clutch, and I can,t remember where all the wires go,the main battery ground cable bolts to the engine block, the main battery + cable goes to the starter +post, but there is one larger cable that looks like it comes from the alternator, this big wire in this picture is down by the starter come thought that plastic wire holder that is bu the cooling fan motor, is this the alternator + lead and does it connect to the starter + post as well as the battery + wire ?
