Thank you. This will be my first diesel and I'm trying to sort through the crap info I'm getting before I start working on it. Is there anything you would recommend doing to a 250,000 mile engine besides the obvious chains, bearings and gaskets?No, it will not. Under normal operation, on a stock engine with everything connected and working properly, a request for full output via your right foot will cause the ECU to shut the EGR off completely anyway.
If you want more power, on that engine, the PROM chips in the ECU get swapped with different ones. In many cases, these aftermarket chips have software that does not use the EGR, but that is not where/how they add power. They add power by increasing boost, fueling, and a more aggressive timing map.
Problem is, on the early engines like that, with their teeny weeny wastegated turbo, you end up with a seemingly lock step increase in black smoke with any power adding. At least that was my experience, but things may have changed. Honestly the newer TDIs kind of left any development with the older engines in the past. Most folks with the older cars like that are just trying to keep them working amidst parts being no longer available, the bodies falling apart and rusting away, and the interior falling to pieces. If you have a really nice example, I'd be more worried about keeping it nice, enjoying its virtues in stock form (which in the light weight A3, the 90hp AHU is reasonably peppy and very frugal).
I enjoyed my A3, and to be honest I think I liked it more when it was 100% stock under the hood.
I'm getting the car this weekend from my father in law. He got it with a major oil leak and no maintenance history. He fixed the leak and is giving to me for a daily after my jeep went down. I usually work on gas engines so I have a basic idea but idk detailsThere are no chains on that engine thankfully.
Does it run OK? A well cared for AHU at only 250k miles shouldn't "need" anything in terms of major mechanicals.
Oil and filter change every 10k miles.
Fuel filter every 20k miles.
Air filter every 40k miles.
Timing belt every 60k miles.
I would want to be certain the alternator clutch pulley is working properly, that the newer style crank pulley/balancer is on there, and that the front sprocket and crank snout are in good order, and maybe inspect the water pump and housing and coolant hoses for any leaks, as well as the injection pump.
I keep hearing they have the same I-shaft bearing problems the 1.6 had.There are no chains on that engine thankfully.
Pre-TDI VAG diesels with bad I-shaft bearing wear are from overtightened belts. Otherwise, they last a very long time. My own '91 had 437k miles on it when I tore it down, and the babbitt was bearing worn off the loaded side of the front bearing. I've owned lots of these, and worked on many, many more.I keep hearing they have the same I-shaft bearing problems the 1.6 had.
They need to be renewed after that many miles.
I usually see them go around 150,000 miles on the 1.6s.
Wise words right there! Save the upgrade money to fix whats broke. So many car come through my shop with 1500 worth of wheels, big expensive stereo systems, lowered with "coil-overs" but yet they cant afford the blend door repair or the TB is overdue.Most folks with the older cars like that are just trying to keep them working amidst parts being no longer available, the bodies falling apart and rusting away, and the interior falling to pieces. If you have a really nice example, I'd be more worried about keeping it nice, enjoying its virtues in stock form (which in the light weight A3, the 90hp AHU is reasonably peppy and very frugal).
