Hallo all VW lovers, trying to find what might be bad at my 2.0TDI engine (CBBB) in a Passat-09. I have fears that the stealer workshop would replace the entire turbo thats why I try to solve the problem on my own.
This is the fault code
1 Fault Found:
009571 - Turbocharger Boost Control Position Sensor Circuit
P2563 - 000 - implausible signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 3
Mileage: 80250 km
Time Indication: 0
Date: 02/14/2004
Time: 12:45:48
Freeze Frame:
RPM: 851 / min
Speed: 0.0 km / h
Voltage: 13.91 V
Lambda: 94.7%
Lambda: -29.2%
Bees. Bits: 00001110
Voltage: 1824 V
The engine has never gone bad or otherwise mark bad condition, the error code is displayed only when I go from D (Drive) to R (reverse) and back to D on the DSG transmission. At first it was only when the engine was warm now it happens almost every time D-R-D is used, but only then.
Have already changed VNT Actuator (G581) and Wastegate (N75) in the car. When replacing the G581 got the same error message up right immediately, when I change the N75 did not come up at once used the car for 2 week and despite D-R-D there was no fault code. Now its back again. Tried all the vacum hoses with brake cleaning and no difference in idle. Someone who has more suggestions or is my turbo gone?
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 80250 km
Time Indication: 0
Date: 02/14/2004
Time: 12:45:48
Freeze Frame:
RPM: 851 / min
Speed: 0.0 km / h
Voltage: 13.91 V
Lambda: 94.7%
Lambda: -29.2%
Voltage: 1824 V
Code:
VCDS Version: Beta 12.10.1
Data version: 20121121
Friday,21,December,2012,16:00:01:51532
Chassis Type: 3C0
Scan: 01 02 03 08 09 10 13 14 15 16 17 19 25 2E 37 42 44 46 47 4F
52 53 55 56 5C 62 69 6C 72 77
VIN: WVWZZZ3CZ9EXXXXXX
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5C-Lane Maintain. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CBB) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 QG HW: 03L 907 309
Component: R4 2,0L EDC F200AG 3736
Revision: 13H01--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 41234 444 51278
VCID: 7AC3CA19351615CEC65
1 Fault Found:
P2563 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 80250 km
Time Indication: 0
Date: 2004.14.02
Time: 12:45:48
Freeze Frame:
RPM: 851 /min
Speed: 0.0 km/h
Voltage: 13.91 V
Lambda: 94.7 %
Lambda: -29.2 %
Bin. Bits: 00001110
Voltage: 1.824 V
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 051 T HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1980
Revision: 04844002 Serial number: 00000810050186
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 247FD461E712B33ECC9
No fault code found.
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 R HW: 3C0 614 109 R
Component: J104 C4 440 V3 0013
Revision: --025--- Serial number: 00000000000066
Coding: 0026925
Shop #: WSC 12476 030 112356
VCID: 2D693145B4D87276137
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 AK HW: 5K0 907 044 AK
Component: Climatronic 130 0303
Revision: 00002001
Coding: 0000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_ClimaAutoBasis_SK35.rod
VCID: 74DFE421DF7263BE9C9
1 Fault Found:
9479699 - Control Circuit for Front Left Seat Heater
B10A6 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 226
Mileage: 80222 km
Date: 2004.14.01
Time: 15:46:30
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000008959217
Coding: E7E28F8B00041A03D7178F0017000000800BFA4764400145170000000000
Shop #: WSC 00123 011 111084
VCID: 335D273D52FC2486453
Subsystem 1 - Part No: 3C8 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 200908 022 0602
Coding: 00049045
Shop #: WSC 00123
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 271008 054 0402
Coding: 00471277
Shop #: WSC 00123
2 Faults Found:
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 226
Mileage: 80195 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.15 V
ON
ON
OFF
OFF
ON
02746 - Bulb for Daytime Running Light; Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 226
Mileage: 80195 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.15 V
ON
ON
OFF
OFF
ON
Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
Part No SW: 1T0 919 475 H HW: 1T0 919 475
Component: PARKHILFE PLA H07 0110
Revision: -------- Serial number: 88591021535971
Coding: 310107
VCID: 40B778F1D34A8F1EC81
Address 13: Auto Dist. Reg Labels: None
Part No SW: 3C0 907 567 J HW: 3C0 907 567 J
Component: AC201 RDW A 031 0232
Revision: 00031000 Serial number: 00000000030077
Coding: 0010000
Shop #: WSC 40270 222 999999
VCID: 32532239ADE62D8E4E5
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 3C0 907 376 HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0069
Revision: 00000000 Serial number: 09100802530002
Coding: 030180
VCID: E6FB0E6911AE012E92D
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__304 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPM2ZESM
Coding: 0012340
Shop #: WSC 05311 000 00000
VCID: 3B4D0F1D7AACECC69D3
Subsystem 1 - Serial number: 6333FTS678072538
Subsystem 2 - Serial number: 6343FTS610152548
Subsystem 3 - Serial number: 6353ETS6KG8EVVNJ
Subsystem 4 - Serial number: 6363ETS6617UUVNJ
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ
Component: J0527 0025
Revision: 00030000 Serial number: 3C5953507CR
Coding: 0201821
VCID: 74DFE421177263BE9C9
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H06 0010
Coding: 00000131
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C8 920 880 G HW: 3C8 920 880 G
Component: KOMBI H03 0132
Coding: 140F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_SK25.rod
VCID: 305728316BEA1F9E381
Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 J HW: 3C0 907 951
Component: J533__Gateway H13 0152
Revision: H13 Serial number: 2900R08A0580D2
Coding: FDAD7F4650461B009002
VCID: 2867C0519B3A575EE01
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 799 H HW: 3C0 959 799 H
Component: IMMO 070 0383
Revision: 00070000 Serial number: VWZCZ000000000
Shop #: WSC 40920 222 180022
VCID: 3E4B060969BEF9EEBAD
Subsystem 1 - Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7662353226
Coding: 010000
VCID: 2961C55540306E56FFF
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 P HW: 1T0 035 680 H
Component: RNS-MID H70 5218
Revision: AB001001 Serial number: VWZ6Z7L7400354
Coding: 04050000010000810000
VCID: 3B4D0F1DBAACECC69D3
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V9 7918
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1533
Revision: 71009005 Serial number: 00000898188917
Coding: 0000253
VCID: 40B778F1134A8F1EC81
1 Fault Found:
00120 - Outside Warning Light/Door exit Light Driver Side
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 5
Fault Frequency: 36
Reset counter: 226
Mileage: 80195 km
Time Indication: 0
Date: 2004.14.00
Time: 17:25:06
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 G HW: 5N1 909 148 F
Component: J500__APA-BS KL.071 0401
Revision: 1AH02234 Serial number: 00081970463402
Coding: 0000258
VCID: 365B1E29418E31AE62D
Address 46: Central Conv. Labels: 3C0-959-799-46.clb
Component: 09 KESSY PQ46 R 070 0231
Coding: 0091080001C6403F3602943F70024FCE50780103242498
Subsystem 1 - Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H08 9001
Subsystem 2 - Part No: 3C0 951 171 C
Component: Neigungssensor 004 0611
Subsystem 3 - Part No: 3C0 951 171 C
Component: Innenraumueberw.004 0611
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No SW: 3C8 035 456 C HW: 3C8 035 456 C
Component: DSP 10 Kanal 0070
Revision: 00H05001 Serial number: 75805000654904
Address 4F: Centr. Electr. II (J533_) Labels: 1K0-907-532.clb
Part No SW: 1K0 907 532 HW: 3C0 907 951
Revision: -------- Serial number: 2900R08A0580D2
Coding: 00000001
Shop #: WSC 05314 000 00000
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1533
Revision: 71009005 Serial number: 00000924488919
Coding: 0000252
VCID: 41B17DF518408616C7F
1 Fault Found:
00121 - Outside Warning Light/Door exit Light Passenger Side
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 5
Fault Frequency: 8
Reset counter: 11
Mileage: 80198 km
Time Indication: 0
Date: 2004.14.00
Time: 18:53:28
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 009 Serial number: 00000000169182
Coding: 0000057
Shop #: WSC 05311 000 08193
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0136
Revision: 00H04000 Serial number:
Coding: 3493000
VCID: 345F242157F223BE5C9
Subsystem 1 - Part No: 1K0 941 329
Component: AFS-Lst.-Modul l 0003
Coding: 00000053
Subsystem 2 - Part No: 1K0 941 329
Component: AFS-Lst.-Modul r 0003
Coding: 00000053
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 5C: Lane Maintain. Labels: 3C0-907-217.clb
Part No SW: 3C0 907 217 A HW: 4E0 907 217 C
Component: J759 HCA 0130
Revision: 00H07003 Serial number: 300208A14000C1
Coding: 0132002
VCID: 2171DD75F800A616A7F
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 3C8 959 703 B HW: 1K0 959 795 Q
Component: J388 TUER-SG HL 0309
Revision: 43004101 Serial number: 00000000673010
Coding: 0000152
VCID: 31512D35A8E0169637F
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 E HW: 1K0 907 383 E
Component: Anhaenger H07 0050
Revision: 3A002002 Serial number: 00000115415494
Coding: 4100000100000000
VCID: 2F552B4D7ED4006621B
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C8 907 441 HW: 3C8 907 441
Component: J772__Rearview 0022
Revision: 00H06000 Serial number: 525PA8-J840168
Coding: 0030008
VCID: E7E5036DD6A41826A9B
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 3C8 959 704 B HW: 1K0 959 794 Q
Component: J388 TUER-SG HR 0309
Revision: 43004101 Serial number: 00000000667259
Coding: 0000152
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 C HW: 3C8 035 730 C
Component: Telefon 012 0822
Revision: -------- Serial number: 35909603472913
Coding: 020101010000000000000400
ASAM Dataset: EV_UHVPremi A02705
ROD: EV_UHVPremi_BY62.rod
VCID: 237DD77D2A1CB406B53
1 Fault Found:
9458193 - Control Module for Cellular Telephone
B1052 14 [009] - Open or Short to Ground
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 226
Mileage: 80187 km
Date: 2004.14.00
Time: 16:55:12
End ---------------------------------------------------------------------
