Old November 25th, 2017, 10:52   #16
wonneber
Where are the 2 leads going to when you get the '1000 ohms' ?
Did you clean the ones under the battery tray? That would have been the time to do it.
There are 2 grounds under my dash. (iIrc)
Right side of the steering column and left side of the dash.
Might be one under the left kick panel for the door. (iIrc)
'if i check continuity between the two bad grounds under battery, they are infinite'
If they are on the same connection bolt they should have continuity.
Remove all under the tray and clean them.
I did not loose my radio settings when I disconnected the battery for this, only the trip mileage & clock.
Old November 25th, 2017, 11:00   #17
yvon g
yes i cleaned all three grounds under battery tray. the two bad brown wires go into a large harness and go towards inside of car. when i checked resistance from battery ground cable to brown wires , i was reading about 1000 ohms. when i checked from one brown to the other, read infinite. did not see ground to the right of steering shaft, but the one to the left is good. i tried prying back the panel to access kick panel. no wires seen there.
yvon g is offline   Reply With Quote
Old November 25th, 2017, 13:35   #18
indysoto
indysoto's Avatar
Wild guess, do you have an aftermarket Stereo?
2000 a4,G60 single mass, KYB AGX(replaced 2x :|), 215/65/r16's...
2004 BEW Wagon w/ Meyerhoff AutoHaus Runonbeer Sticker
indysoto is offline   Reply With Quote
Old November 25th, 2017, 20:27   #19
yvon g
no i do not
Old November 25th, 2017, 21:16   #20
indysoto
indysoto's Avatar
Originally Posted by yvon g View Post
no i do not
Darn..Dunno how much water this holds but someone mentioned in another thread that putting the car in reverse was enough to tweak a leaking vaccum hose and cause a stall. Maybe look and see if there are any danglers near the linkage? or set your cell video up and see if the motor tweaks slightly.
Old November 26th, 2017, 04:37   #21
yvon g
OK, but when it stalls, the dash lights go out, back up lights don't work,and now air bag light comes on when park brake applied.
Old November 26th, 2017, 08:04   #22
yvon g
Originally Posted by wonneber View Post
The dashboard parking light and the air bag spiral spring (in the steering wheel) both ground at the same point.
Below left side of the dash.
Maybe a bad ground feedback.
Its also a spot water from the sun roof drain can rust if I recall correctly.
where exactly do mean by below left side of dash? are you talking about the two browns about 2 inches from steering shaft? or behind the left kick panel? i tried pulling back the carpet and looked to see a ground point but i didn't see any wires in that area. the two by steering shaft are good.
thanks for any additional input. i guess what I'm looking for is a common ground for these circuits :back up lights, park brake and air bag system. also, if the air bag light is on, engine cranks but no start.
Old November 26th, 2017, 08:59   #23
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Have you ruled out that all this is not just a really old really wore out battery?
Old November 26th, 2017, 16:01   #24
yvon g
yes i did, since starting is no issue and every else is normal except for problems listed in first posts.
Old November 26th, 2017, 19:50   #25
indysoto
indysoto's Avatar
Weird..Might try resetting the computer,
https://itstillruns.com/how-to-reset...ars-10064.html
If that not it like others said..
track down all the grounds clean up the rusty dirty ones take off nuts wire brush and coat with smidge of oil, reassemble
Old November 26th, 2017, 22:27   #26
whitedog
Check my no start thread in the stickies in TDI 101. I seem to recall the same thing happening to someone and it was in the wiring but I don't recall the details.
Old November 27th, 2017, 19:18   #27
wonneber
I got the location from wiring diagrams I have.
It gives a general location.
Could be the one you mentioned.
Old November 28th, 2017, 17:35   #28
yvon g
the one at bottom of left a pillar is the one i could't see.if it 's there, I'll just have to peel back more carpet to find it. the light itself doesn't bother me that much, but lately, the colder it gets, the longer the air bag light stays on. just worried that if that ground location is for other circuits as well, my problems could get worse. thanks in advance for info you can provide.
Old November 28th, 2017, 20:51   #29
indysoto
indysoto's Avatar
Did you reset the computer/ecu?
dies when put into gear lps doug VW MKIV-A4 TDIs (VE and PD) 5 February 13th, 2013 07:08
2010 TDI stalls in reverse, battery dies? Alan Drake TDI 101 0 January 19th, 2013 07:18
Dies in reverse automatic zeigbo VW MKIV-A4 TDIs (VE and PD) 1 March 14th, 2011 11:08
Gearbox Grinding When Put in Reverse 1999Jetta VW MKIII-A3/B4 TDIs 8 September 4th, 2010 17:19
Put in reverse and car went forward brent_f250 TDI 101 13 April 23rd, 2010 12:23
Page generated in 0.17467 seconds with 11 queries
[Output: 118.79 Kb. compressed to 99.22 Kb. by saving 19.57 Kb. (16.48%)]
