Old January 24th, 2013, 08:46   #1
lps doug
Fuel Economy: 40-45
Default dies when put into gear
hey there. so i have a 2002 tdi jetta automatic.
the car starts up and idles but when you put it into gear it drops off and dies.
It has a new ECU and a pump but the problem started before I did all that.
any suggestions? All/Any
2002 Volkswagen GLS TDI Jetta, 20H.P. nozzles, 2 1/2" SS exhaust 4" turndown, AFE intake, more mods coming soon
2006 dodge ram 3500 big horn 5.9L cummins, S&B, Edge Juice with Attitude, DiabloSport Predator, more mods to come
lps doug is offline   Reply With Quote
Old January 24th, 2013, 12:33   #2
Dave_D
The automatic transmissions in the 2002 TDIs are notorious for failures of various kinds. The behavior you are observing suggests such a failure to me. I would suggest you search here for more information on "01M transmission" and see why many are replacing these with a 5 speed manual transmission when they fail.
Dave
1999.5 (A4) Tornado Red Jetta GL TDI,5 speed,4 door, RC 2+, Old Navy CCV mod, ventectomy, CAT filter
Dave_D is offline   Reply With Quote
Old January 24th, 2013, 15:34   #3
lps doug
Fuel Economy: 40-45
thanks dave. i plan on doing a 5 speed swap as soon as i can afford it. but i would like to find find the problem first
Old January 24th, 2013, 20:27   #4
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
Trans failure internally. Seen it before.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old February 13th, 2013, 06:53   #5
lps doug
Fuel Economy: 40-45
it was the MASS air flow sensor
Old February 13th, 2013, 07:08   #6
whitedog
Doug, thanks for the follow-up. I would enjoy learning about the troubleshooting that got you there. Those things can help others when they have the same trouble.
Can I put a 6th gear in my 2002? HarleyGuy TDI 101 22 January 8th, 2013 10:30
Can I put a 6th gear in my 2002? HarleyGuy VW MKIV-A4 TDIs (VE and PD) 1 December 28th, 2012 14:33
car dies then gose into limp mode with only 3rd gear ( HELP) dlewis VW MKIII-A3/B4 TDIs 1 February 23rd, 2012 21:01
After 4k RPM power dies off, Happens only in 1st gear, AUTO, New MAF. Pcar993 TDI Power Enhancements 25 April 12th, 2010 13:58
Can put NEW car in gear! lazlo VW MKIV-A4 TDIs (VE and PD) 4 March 3rd, 2000 19:20
Page generated in 0.13867 seconds with 11 queries
[Output: 75.09 Kb. compressed to 65.31 Kb. by saving 9.78 Kb. (13.03%)]
