Old January 19th, 2013, 07:18   #1
Alan Drake
TDI(s): 2015 DSG
Default 2010 TDI stalls in reverse, battery dies?
Went out today, started car, put in reverse - auto trans shutters, so back into neutral but it stalls, attempt to start - but battery is almost gone, ie very slow turn over.
Too bad I can not check fluid level in trans. The reverse shutter has happened before but goes away in a few minutes.
Car has 30K miles, garage is 50 F any ideas? Yes, did some search work however nothing found - may not be using correct terms since I get nothing or toooo much. Also not sure if this is correct area to post question?
2010 Jetta Sedan
2004 Duramax
Alan Drake is offline   Reply With Quote
Auto TDI stalls/dies at start from stop gfunk79 TDI 101 6 December 17th, 2012 13:33
2005 Passat TDI stalls in reverse on cold start EDT TDI VW B5 Passat TDIs 4 August 3rd, 2009 10:52
2005 Passat TDI stalls in reverse on cold start EDT TDI VW B5 Passat TDIs 0 July 20th, 2009 21:18
2005 Passat TDI always stalls in reverse on cold start EDT TDI TDI 101 8 July 20th, 2009 21:10
If Your TDI Quits Stalls Stops Dies / Relay 109 EtherNut VW MKIII-A3/B4 TDIs 8 September 25th, 2003 10:45
Page generated in 0.16589 seconds with 11 queries
[Output: 46.86 Kb. compressed to 44.10 Kb. by saving 2.76 Kb. (5.89%)]
