Jason Rowe
Hey guys.
Would any of you have an idea as to what may be causing my issue?
The (cold start injector) advance solinoid N108 is activating when it shouldn't. The vehicle has a bit of a rough idle, and won't rev past 3k rpm. I put a switch on the engine management fuse, I forget the number. When one takes out the fuse, or uses the switch to in essence turn it off. The engine is happy to rev up all the way, obviously no boost. Because it is going to a default map. As soon as one connects power back to the cercuit, the ecu is telling the advance solinoid to activate and cause rough running, with no boost, and will hardly accelerate.
All the other sensors on that circuit are good, I have switched them with another vehicles sensors, and the car will still run well. I have voltage tested the all of them too. They are all okay. I have gone through the entire wiring system to make sure there are no chafed wires, and cleaned up any that are bad. I just cannot for the life of me figure out what is going on.
I would really appreciate some advice or info if anyone knows anything about this.
Kind regards
Jason
Kind regards
Jason
