Sonia's_Driver
I am having an issue with my bumper side marker lights.
To refresh your memories, they are the ones that are mounted on the bumper, in an amber retro-reflective housing, and take a wedge-base capsule bulb into a base that slips onto the back of the housing.
I replaced one a couple of years ago because the part of the mount that the base slips around had melted off. (After I got tired of having to duct-tape the base to the housing.)
Now, both mounts have melted off of the housings. One of the bases was hanging down and dragging on the pavement last time I changed the oil.
Presumably, I accidentally replaced the bulbs with bulbs that have wattage higher than the OEM bulbs at some point in the past. (I haven't seen any threads about this, so it must not be a common issue.)
Anyway - does anyone know of a kit that would allow me to retrofit in an amber LED lamp to these housings? IIRC the housings are like $45 each, so even an expensive LED kit would be cheaper than 2 replacements...
Thanks in advance.
Thanks in advance.
