WolfgangVW
Hi all. So recently my brakes on my 2003 Jetta started squeaking pretty bad. The rear pads were low so I replaced them thinking this might be the issue. The squeaking is far better but still a little squeaking and even just the faintest at times when I'm not even applying the brake. Any suggestions on a fix or anything? Is it normal for the brakes to squeak after replacing until they break in? I've maybe driven 30km since replacement......
As well the rotors I didn't replace they were smooth and still thick enough I believe....
