rallywagon
I am pretty sure that what I thought was a lifter or injector is a rod bearing tapping. It's on my son's 2000 Jetta ALH with 310K miles....purchased cheap ($1300) a couple of years ago with a tap and a patched up oil pan. Daily driver for him now.
Unfortunately, I did not suspect a rod bearing (sounded like a lifter to me) when we replaced the oil pan shortly after purchase. I would have at least checked for movement back then. But now, after unsuccessfully trying to find the tap up high along with remembering that the pan was JB welded back together by the previous owner I am pretty sure it's a rod bearing.
I would like the car to hold together for at least another year or two as my son will enter college within that window. It is doing fine except for this tap.
Questions:
1. Could I pull the pan and replace the single tapping rod bearing from below without loosening the crank or anything else? I know it is less than ideal, but would this likely improve the situation / reduce tap and risk?
2. What is the thickest oil I could safely run in the mean time? 15W-40 too thick? I normally use Mobil 1 0W-40 in all of our cars.
3. Any other short cuts / tips to keep the car going and minimizing the rod risk?
This is my second TDI...I have 270k miles on my '98 Jetta, and I am pretty good at wrenching.
Thank in advance for all information and thoughts!
Scott
Questions:
Scott
