CoolAirVw ........... awesome! Fantastic !
I love photos and YouTubes! They remove most doubts and questions. A visual is great for filling in all the perceived missing pieces! Thanks for posting!
Thanks so much. All I get for making these videos is a thank you every once in awhile. I get some negative comments too, which is ok, I understand its the internet.
Question/comments..
Pressures are affected by temperature and volume of refrigerant in the system (not enough or too much). Do you measure (weigh) the volume or just go by the sticker spec? I've noticed on some vehicles the sticker spec has a + or - that is almost a 10% swing up/down.
I ask and comment because with my Vanagon, I have no clue what the required amount of R134a is necessary for optimum cooling. So, I just add refrigerant until the high side pressure is about 275 psi with ambient temp in the range of 78 to 85f (low side 35 to 45 psi). Also, I use a box fan out front of van to add extra air. With this scenario, I'm getting temps in the low 40s out of the vents. Generally, it takes slightly more than two 12 ounce cans to achieve these numbers. What's your thoughts on those pressure ranges?
I like your pressures, but honestly it would be best to find a weight spec and have someone put the exact quantity in that it requires, but I'll bet yours leaks a bit, and then you would have to have them do it every year, so if yours is working fine I guess if it ain't broke then don't fix it. On most systems the way your doing it is accurate enough. Obviously if your getting 40 degrees out of the vents then its probably just fine.
AC machines are required by law for a shop to service AC systems. Those machines weigh the freon and that is the only way to accurately know the quantity. So of course we add based on weight.
I tried to look up how much freon your Vanagon would take but its too old and my tech service info doesn't show it. Maybe your Bentley would?
I would assume that yours originally was a R12 system? How did you convert? I had a discussion with a customer regarding his plans to upgrade his system and this is what we came up with.
1. Upgrade rubber hoses to solid lines where possible (under van) to slow down "yearly leaks". And of course replace the rubber hoses that are necessary.
2. Upgrade to a compatible condenser for R134 since there is major design difference from R12 and R134 there that could hinder performance.
3. Fabricate rear air system.
4. Upgrade to a modern compressor, whether aftermarket or from a later vehicle (Caravan or a big Suv) with rear air.
5. Tint windows to keep the sun out.
We never did this but would be excellent to see someone who did.
