Wasn't sure if I should post here, or General Discussion, excuse the duplicate post.
Wife's 2003 Jetta TDI (85k miles) has been losing turbo boost once in a blue moon, but it happened twice on her way to work this morning, and she got a Check Engine Light (finally) to boot. I assumed the N75 valve was going, but the dealer says that its the MAP (not MAF) sensor and wants $482 to do the job. I've been looking for a DIY on MAP sensor replacement, but haven't found it.
Does a faulty MAP sensor sound like a reasonable diagnosis, and can anyone provide a link to a DIY page?
A little more detail. I talked to the service advisor, and the error code is P0108 (DTC 16492) "Manifold ABS Pressure or Bar Pressure High Input", which doesn't sound like a sensor failure to me, it sounds like I there is high pressure, and sensor is reading it, causing the car to go into limp mode?
I do have an "Elephant Hose CCV" (CCV is open to the environment), and it did just start getting cold around here, I wonder if that could trip the CEL? I'm going to skip having the dealer replace the sensor, and hook the CCV back up the way it came from the factory.
Any thoughts?
More info, the MAP sensor seems to run between $100-$140. Bosch P/N: 0 281 002 177, VW P/N: 038 906 051.
Any thoughts?
