What is your other diesel?
wolfman
columbus, ohio usa
BMW 335d, Passat 2013 TDI SEL; Former - 1999 Jetta TDI, 1994 GMC Sierra 6.5 TD, 1983 Ford 6.9 IDI, 1986 Chevy 6.2 Diesel Pickup, VW Rabbit Diesel pickup
Current Diesels:
2009 BMW 335d
2013 Passat TDI SEL (just bought yesterday and started reading the forum again!)
Previous Diesels:
1982 VW Rabbit Caddy Diesel Pickup
1986 Chevy 6.2 diesel pickup
1994 GMC 2500 6.5 turbo diesel
1983 Ford F-250 6.9 International Diesel
1999 VW Jetta TDI
2006-2009 BioDiesel making project (gave this up after developing new appreciation for fuel pumps)
K0TY
Watertown SD
2015 VW Passat 2.0L TDI SEL
Current diesels:
2015 VW Passat TDI SEL
2003 Dodge Ram 2500
Previous diesels:
2013 VW Passat SE
1999 Ford Powerstroke
1979 Oldsmobile Toronado
efeballi
Istanbul, Turkey
2004 Seat Altea 2.0 TDI (BKD)
Current diesels:
2014 Renault Fluence 1.5 dCi (90 hp, YAWN)
Previous diesels:
2005 Ford Focus 1.6 TDCi
Sent from my calculator using Tapatalk
09jettaloyale
Near Springfield MA
2013 Passat TDI SEL, 2013 Passat SE DSG, 2001 F-250 PSD
Have 2 2013 Passat Tdi's
2001 Ford F-250 with 7.3 with 75,000 miles
1993 Ford 1920 tractor with 4 cylinder Shibura diesel
Peroni
Mocksville, NC
2005 Mk4 Jetta TDI, 2014 Passat TDI SEL, 2015 Jetta TDI SEL
2014 Passat TDI
2006 Jetta TDI
1997 F350 7.3
JD 455 lawn tractor
JD 500C backhoe
Bucyrus Erie 22B w/ Cat D318 engine
Agrozet MT8-162 w/ Kubota D1302 engine
Hatz air cooled diesel
Lombardini air cooled diesel
Skimax
White mts, NH
97 B4 variant(retired at 330K), 2000 B5 1.8T passat retired, 2013 SE (buyback5/17) 2015 SEL, 2015 E-Golf SEL sold March 2019, 2018 Volt LT and a 2007 PRHT MX5 for fun
2013 Mack Pinnacle single axle, MP7 engine, 10 speed Eaton Fuller transmission
2009 JD 3120 compact tractor
tadawson
Lewisville, TX
2013 Passat TDI SEL, 2015 Passat TDI SEL
2011 RAM 2500 crew cab, 8' bed with a Cummins 6.7 . . . It has also been issue free . . . . and does 20MPG on the open road, with stock emissions.
- Tim
atoughram
Puyallup Washington
2013 Passat SEL
I love the smell of diesel in the morning....
1999 Dodge Ram 2500 SLT 4X4 5.9 SO Cummins/NV4500 5sp/NP241HD Transfer Case, Edge Drag Comp,F1 Diesel Mach IV Injectors, F1 Diesel Helix 2 Cam, PDR40-16/S400 twin turbos from Source Automotive, Source Automotive 5" Exhaust, South Bend MU 13-1.25 Con FE clutch, 12V Mechanical Lift Pump, Vulcan Draw Straw and "Big Dog" -8an fuel lines, Solid Steel Track Bar, DSS, Buckstop front bumper carrying Mile Marker 10,500 Hyd. winch.
jason_
michigan
2015 s wagon dsg
I need a 2" Reese up front. Makes life sooooo much easier moving stuff around solo.
Sent from my One using Tapatalk
monkfarm
Pepin, WI
06 bug TDI, 2012 Jetta Sportwagon TDI bought back, 2017 Subaru XT; 2015 F150 Lariat with ecoboost 3.5, 99 Dodge Cummins 1 ton flatbed
other diesels
'12 jetta sportwagen
'06 bug tdi
'99 Dodge cummins 1 ton flatbed
'70 Ford backhoe
miller diesel welder "bobcat"
;) one cylinder diesel military engine; runs hydraulic pump
jrm
Oregon
2013 Passat SE with nav (totaled)
Just drive 2k miles round trip to Barstow cali to pick up my govplanet military auction win- a sweet smooth quiet 10K 4 cylinder diesel genset for home backup power! MEP803A for anyone looking for one.
Came with a full tank of JP8 fuel, its like old school ultra high sulphur- the exhaust is like 1980's caterpillar smell and a solid aluminum trailer with like new Humvee tires with the whiskers still on them!
Spike_africa
Sarasota,FL
2013 Passat TDI/w DSG
It was a 2006 Jetta TDI in black. With TDtuning 40hp tune, water/meth injection, drop in filter, better pads and fluid, and other things like HIDs, LED upgrades etc... great little car. Sold it to my brother in law.
Cashcropin
Michigan
2014 Passat tdi se dsg
2000 f250 7.3 psd , 94 Freightliner n14 cummins select 450 hp,88 ford l9000 with l10 cummins 300 hp, 1974 allischalmers 7040 135 hp,1972 ford 5000 tractor 75 hp , 1993 Johndeere 9600 combine 220 hp , previously owned three vw rabbits and a 2000 vw Jetta tdi 5 speed
Powersmokin
Colorado Springs
2014 Passat TDI SEL Premium
My 96 F350. Done a lot to it, but the most notable mods are - Intake, exhaust, TS-6 chip (soon to be replaced with a PHP Hydra), Swamp's 160cc injectors, 19* HPOP, 3" lift, 35s
jrm
Oregon
Watch the EGT's on the 7.3 as my friend didn't...
jrm
Oregon
Here is my single cab 12 valve. Mechanical upgrades:
Fuel plate, 15 degrees, Marine 6bt injectors, Boost elbow, Goerend Transmission with low stall converter, disk brake dana 70, box brace, redhead box with only 12 turns stop to stop vs 15.
jrm
Oregon
yeah his PSD was a mirror image of yours- he ended up selling it as is and picked up a '99
How heavy was that Hoe? Looks like 20K including tong weight :D
Dodoma
2002 Jetta White
When will be see diesel engines without the use of urea injection or others to meet the clean act requirements?
jrm
Oregon
I hope soon as a Atkinson cycle diesel (Toyota Prius design) would completely eliminate nox as the computer can change the displacement and compression on the fly by holding a intake valve open thus reducing compression without changing the fuel to air ratio.
Powersmokin
Colorado Springs
The excavator was 13,500 lbs. the trailer, im guessing is like 4-5,000. So around 18,000lb total weight.
I would recommend the same thing lol. The new body style trucks have better interiors and more upgrade-ability.
Dodoma, the problem with diesel engines, is that they are scored (emissions wise) on two parameters, Particulate Matter (PM) and Oxides of Nitrogen NOx.
Some interesting things happen at the tailpipe when you change injection strategies.
NOx and PM have a direct, but inverse relationship to combustion temperature.
When combustion temperatures are lower, PM increases and NOx decreases.
When combustion temperatures increase, PM decreases, but NOx increases.
With the urea injection system, Urea is injected into a catalyst that breaks NOx into ammonia and nitrogen. The Urea breaks down the ammonia in an an ammonia oxidation catalyst to hydrogen and oxygen? I think? So the only things coming out of the exhaust are water, and nitrogen.
The talk of new diesel engines is doing away from the DPF (particulate filter) but relying heavily on urea. If you increase the injection temperatures hugely, you can burn off all the PM, but have raised NOx, using more urea.
Hope that provides insight to your question lol
As for the atkinson engine, all I could find on that is just volumetric efficiency. No emissions changes.
