toddster900
Hi All
I have recently been using about half a pint of water every 500 miles on my 03 Mk4 Golf TDI 130. The coolant is also overpressurising and has tested positive for combustion gasses. As a result I am in the process of changing the head gasket.
I now have the head removed and there are very slight ridges on the head along the circular outline of the cylinder bore. The ridges seem to be metal rather than carbon. It is not all the way roun the outline but is present in parts on all cylinders.
Apart from that the cylinder and block look in good condition considering the 210k miles it has done.
Has anyone seen these ridges before?
