RattlenHum
- Joined
- May 4, 2001
- Location
Loud "pop"...car billowed thick black smoke from...engine fluctuates then stalls
I have a few questions that I would be most thankful for any help.
SYMPTOMS
On my way home from the VW dealer today, my B5.5 TDI made a loud "pop", which sounded similar to the sound that a "potato gun" makes when launching a potato. Immediately thereafter, I noticed thick black smoke billowing from the exhaust. Then, the engine started to surge and lose power. I immediately pulled off to the side of the road. Called VW dealer and had car flat bedded back to dealer. There was no CEL light visible, but I am sure there are some codes that were thrown.
BACKGROUND
My car had some front end damage, which I took to the dealer to have repaired. The repairs consisted of straightening the front frame rails (as they were slightly bent) as I noticed that prior to repairs, that the front hood was sticking slightly over the front grill, similar to a person who has an over-bite. Some of the pieces that were replaced were: front support bracket (that runs horizontally), the cross tube, buffers, etc.
DIAGNOSIS?
I am guessing that in order to repair the front end of the car, that the intercooler and related plumbing had to be removed. So, I am guessing that the intercooler was not put on properly and blew off?
OTHER
The car currently has 123,000 miles and has been very reliable. The car was "unchained" at around 90,000 miles.
I appreciate any help that you all can provide. I am at a loss as to the problem. However, I want to be as informed as possible so that I don't get screwed by the dealer.
Thanks very much,
Andrew
SYMPTOMS
BACKGROUND
DIAGNOSIS?
OTHER
Thanks very much,
Andrew
