Old September 10th, 2010, 09:32   #1
4Cornered
TDI(s): 2002 Golf
Default Totally confused; need help
I have a 2002 Golf TDI with 108,000 miles. It has progressively started to lose power and make noise in the last week. Yesterday, while returning from a test drive, I noticed that it was producing black smoke while going uphill. The idle seems much the same as usual, perhaps a bit louder, but I have both the upper and lower covers off. I have VCDS and the only DTC codes being produced are intermittent glow plug failure. I ran the basic settings tests and the solenoid for the turbocharger is moving freely. I checked to see if the car would rev to 5100 rpm in neutral after being warmed up, it does. There is a clattering noise which started occuring during acceleration in 2nd through 4th gear in the 2000+ rpm range. I've cleaned the snow screen, checked the air filter, run it with and without the MAF plugged in (no discernable difference), run it up hill in 3rd, 4th and 5th gear with Wide Open Throttle. I am hoping someone might have suggestions and have a couple of questions.
1) If the car is going into limp mode, will it always (or commonly) produce some DTC that the VCDS will find?
2) Could the power loss, noise increase and smoke production be the result of an injector (or injectors) getting progressively plugged? If so, how can I tell if it is an injector problem, or something else.
3) Could the problems be from a sticking (failing) valve? Seems unlikely, but how could it be ruled out? The car has been lubed with synthetic oil since break-in and has virtually no consumption between changes.
Any help would be appreciated; its a 90 mile round trip to the nearest town with a dealership.
4Cornered is offline   Reply With Quote
Old September 10th, 2010, 09:40   #2
dieseldorf
top post dawg
dieseldorf's Avatar
Limp mode certainly does NOT always set DTCs.
has the intake manifold ever been cleaned? Is the MAF sensor original?
Old September 10th, 2010, 09:58   #3
Joester
Joester's Avatar
Fuel Economy: 52/42/28
i would think MAF if there was no noticable difference. if you unplug a good MAF you will definitely definitely notice the difference. its like half as fast as it was.
2002 VW Golf 4dr 5spd TDI ---- Malone stage 4 - Borg Warner BV-39 - PP520 Nozzles - South Bend Stage II Daily Clutch - TacoTaco Intercooler - Bilstein Sport Shocks and Struts on H&R Sport Springs - 17x7 Long Beach Wheels with Bridgestone S0-4 Summers - General Altimax Arctic on Stock 15s for Winter
Joester is offline   Reply With Quote
Old September 10th, 2010, 10:08   #4
Tom W.
Tom W.'s Avatar
Fuel Economy: Getta 49MPG IDI 60MPG Passat 34mpg
Loosing power, make noise- could be you have a leak somewhere between the turbo and the intake manifold. Not unusual . You have to put the car up on ramps, climb under while the car is running, and listen/look/feel all along the pipes from the turbo to the intercooler, the intercooler itself, and all the way up to the intake manifold. could be a split pipe, or a loose clamp- I've seen both.
Chemically cleaning your turbo: http://forums.tdiclub.com/showpost.p...8&postcount=48
canadiangrizzly's Diagnosing limp mode: http://forums.tdiclub.com/showthread.php?t=179589
GoFaster on loss of power:
http://forums.tdiclub.com/showthread.php?t=75959
Tom W. is offline   Reply With Quote
Old September 10th, 2010, 13:10   #5
4Cornered
TDI(s): 2002 Golf
Default Responding to comments
Thanks for the suggestions:
1) The MAF is orginal.
2) Have had the car up on ramps while checking the turbo soleniod. I did not notice any leaks. Would the graphing Manifold pressure in VCDS indicate low pressure in the intake between the compressor side of the turbocharger and the intake valves?
3) The intake manifold has not been cleaned.
By the way, my wife drives the car to work, her commute is 14 miles one way over a 7000+ foot pass. So the car does get warm, and it has been doing this climb twice a day at 70 mph in 5th gear until recently.
Old September 10th, 2010, 13:47   #6
dieseldorf
top post dawg
dieseldorf's Avatar
These are both immediate conceners, IME.
The intake will need to be cleaned.
The VCDS test for a failing/failed MAF sensor isn't quite as good as it should be. I'd give strong consideration to getting a fresh one in there. The part is inexpensive. It can do amazing things for restoring driveability as the failure is often gradual.
Old September 10th, 2010, 15:31   #7
4Cornered
TDI(s): 2002 Golf
Default Will try these
I have a replacement MAF ordered, while waiting for it to get here, I'll clean the intake manifold. Hope that clears things up. As is my wife is using my 1984 Subaru to commute and making comments regarding time to go over pass.
Thanks for the suggestions.
Old September 10th, 2010, 15:35   #8
dieseldorf
top post dawg
dieseldorf's Avatar
My pleasure. Let us know how else we might help.
I hope doing these fairly minor tasks returns your 2002 to better than new operating condition. A weak/failing MAF sensor can turn these cars into total pooches.
Old September 10th, 2010, 15:45   #9
75r90rider
In my experience, dieseldorf is 100% on the money.
75r90rider is offline   Reply With Quote
Old September 10th, 2010, 15:48   #10
dieseldorf
top post dawg
dieseldorf's Avatar
Ohh, you're much too kind Yes, you're correct, I am a fellow Airhead
Page generated in 0.10285 seconds with 10 queries
[Output: 93.93 Kb. compressed to 79.70 Kb. by saving 14.23 Kb. (15.15%)]
