Old November 14th, 2019, 14:25   #1
gunnerthesnowman
Default 2004 TDI BEW glow plugs
Which are the right ones?? https://www.rockauto.com/en/moreinfo.php?pk=33522&cc=3163&jsn=2038&jsn=2038 These ones are $36 VOLKSWAGEN N10591601
Engine Code BEW; 10 x 1 x 25mm
1 Day Delay
These ones are $46
gunnerthesnowman is offline   Reply With Quote
Old November 14th, 2019, 14:33   #2
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
Cant say - not that I'd ever buy anything from rockauto (see signature). There were multiple versions on the BEW depending on what level of recall was performed. You need to know which is correct for your specific car.
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is online now   Reply With Quote
Old November 14th, 2019, 14:34   #3
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
There was a recall (or TSB) to switch from one voltage to another. They flashed the ECU and changed the plugs. So you may want to call the dealer or otherwise find out you which plug (5v or 7v) yours wants. Simpler is to pull one and put the same back in.
Old November 14th, 2019, 17:02   #4
JDSwan87
Black Swamp Thing
JDSwan87's Avatar
There was actually 3 TSB's/recalls for the BEW glow plugs. You also can't go by what's in there either as some dealers flashed the ECU but didn't change the Go's.
What I did was disconnect the coolant temp sensor and checked voltage at the start of the GP cycle. Mine flashed 7v for about a second, the tapered off. I installed 7v NGK ceramics and start just fine in 8*F weather.
There is also a way to check your ECU software revision with VCDS, but I can't remember the details...
Stella (Mine now): 2005 Shadow Blue Jetta Wagon TDI 09A
Mods: RC1. VCDS HEX-CAN USB (near Toledo, OH)
JDSwan87 is online now   Reply With Quote
Old November 14th, 2019, 19:30   #5
zslnk
If you have 7v programming that is the correct plug. if the car starts well in the cold now (or before the plug failed) and what you pull out is a 7v plug that one is correct.
zslnk is online now   Reply With Quote
Old November 14th, 2019, 19:58   #6
I show that part number as fitting the engine after the BEW, the BRM. Not the same plug. Your car either has 5v plugs (N10591607), or 7v ceramic, (N10591609). Best way to find out what you need is, as others have suggested, pull a plug and look, or call a local dealer with your VIN and find out what glow plug recalls have been performed on the car. They can then tell you what voltage the ECU is flashed for and what plugs to use.
2002 Jetta wagon, 400K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old November 14th, 2019, 20:50   #7
zslnk
Yes it’s a BRM plug.
My understanding (from dealer buying by VIN and reading here) is that the 109 was the correct 7v plug. Vw changed to the 108 for the BRM but was comparable in BEW so they sell one part for both. Slight difference in length.
I’ve had both 108 and 109 in my 2006 (BEW wagon) car that never had any recalls done.
BEW Glow Plug Recall, worn glow plugs at 1 year Fasteddie10 VW MKIV-A4 TDIs (VE and PD) 9 May 5th, 2016 06:32
new bew glow plugs zukvw VW MKIV-A4 TDIs (VE and PD) 5 February 13th, 2011 14:42
Latest on glow plugs 2004-2005 Jetta tdi ssrcar Atlantic Canada 1 October 5th, 2010 09:31
FS: 3 Used Ceramic TDI Glow Plugs - BEW rhussjr Private TDI Items for Sale/Wanted 12 September 18th, 2009 17:47
BEW Glow Plugs PapaBare VW MKIV-A4 TDIs (VE and PD) 2 August 11th, 2009 22:47
Page generated in 0.13380 seconds with 12 queries
[Output: 80.88 Kb. compressed to 70.25 Kb. by saving 10.63 Kb. (13.14%)]
