<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by GoFaster:
That's part of the automatic advance mechanism (it's where the actuator lives) but that's not where you adjust the timing.
Before even THINKING about fiddling with this, get your hands on a VAG-COM and find out where the timing is now. (More later.) It may not be necessary to do anything.
To adjust the timing on an A3/B4, you loosen the 3 bolts which hold the front flange of the injector pump to the mounting bracket and 1 more bolt which supports the rear of the pump, in order to gain access to two of the 3 bolts you'll have to remove the upper timing belt cover and rotate the engine until you can get them through the holes in the sprocket. Also crack loose the fuel line fittings. Then rotate the pump a little bit (just like adjusting distributor timing in the old days). Snug everything up, DO NOT OVERTIGHTEN the injector lines, then start the engine and re-check the timing. It is a trial and error process.
On the A4 cars, you take off the upper timing belt cover, loosen the 3 bolts which hold the outer part of the pump sprocket to the hub, shift the sprocket relative to the hub, and re-tighten. Once you get it set up, replace the 3 bolts with new ones (do them one at a time so you don't lose your setting).
Now for the fun stuff: explaining how it works. The injection timing is under automatic control, regardless of your manual setting UNLESS the automatic control reaches the limit of its travel (in which case it obviously cannot adjust it any further). Also the manual setting affects injection timing during starting, because the automatic systems aren't operating at that time.
If the computer wants 2 degrees BTDC, it will get 2 degrees BTDC, unless your manual setting doesn't allow that setting to be achieved.
Stock timing at warm idle is 0.4 degrees BTDC. Mine is set to 2 degrees BTDC - it's advanced far enough that the computer cannot retard the timing below 2 degrees BTDC at idle.
<HR></BLOCKQUOTE>
Brian P.,
Yeah, I knew all that stuff already. What about the ability to adjust/meddle with the advance charateristics with whatever is under that cap? The manual (or static) timing is okay as long as the car starts, within reason of course. My '97 Jetta TDI starts and runs fine, actually, great. I'm trying to get more mileage/range per tank of fuel. I'm trying to maximize fuel economy for highway runs. Maybe, if I canget a little more efficiency, I can get more range. So, what gives with that Timing Control Cover, as it is called in the Bentley Manual. (Bentley Manual for VW Jetta/Golf/VR6 &TDI, 1993 to early 1999. See page 23b-10, Figure 9, Item Number 21.)
Is there some sort of adjustability under the Timing Control Cover? I tend to think not since the performance "maps" would set the dynamic timing per the maps. This is after all, a closed-loop system that uses look-up tables, or maps to determine the injection timing.
Thanks,
Al K.
Boundless
1997 Jetta TDi
