dieselvergnuegen
I am still unclear about the exact steps necessary to do the mechanical injection timing adjustment (ALH, 2002 Automatic GOlf TDI) after reading the TB-FAQ and many posts.
Lets assume I use the Vag-Com timing procedure from page 110(=118in pdf) of the TB-FAQ:
Are a) and b) the only steps needed before continuing on page 110/118?
a) Turn off engine. Remove intake hose from EGR to intake manifold
b) Remove timing belt cover
c) Anything else?
d) Loosen 3 bolts rotate IJ pump forward or backward a few degrees
e) Re-tighten bolts with correct torque (18Ft-lbs/24Nm for non-stretch type)
f) Reinstall TB cover ?
g) Reinstall hose?
h) Start engine, check timing
i) Go back to a) if not right?
- It seems there is very little space to get to the 3 bolts and get the torque wrench in. Any recommendations for which tool to get?
- Can I quickly start the engine and test the timing without timing belt cover on?
- Without intake hose connected I assume would be bad because engine would get unfiltered air?
Thanks a lot for any comments. As you can see this is the first time I am trying this.
Looking forward to bumping up my 110C value from 38 to 70. Hopefully will improve my 32 MPG (highway) somewhat because even for an automatic I should be able to do better.
c) Anything else?
g) Reinstall hose?
