DidJettarun
I have looked at other threads regarding batteries dying overnight. I have recently had the same issue...get it to start and it will start fine all day...1st start of the day battery is completely dead. Dang144 looked at the VCDS and here are the codes
Saturday,05,February,2011,15:15:46:39623
VCDS Version: Release 10.6.3
Data version: 20101206
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Control Module Part Number: 1K0 907 530 E HW: 1K0 907 951
Component and/or Version: Gateway H09 0110
Software Coding: 3F7F0B620F1002
Work Shop Code: WSC 00066 000 00000
VCID: 295311D8F97F
1 Fault Found:
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 8
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 03:07:01
And
Saturday,05,February,2011,14:57:46:39623
Chassis Type: 1K0
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 47 52 56 62
72 7D
VIN: 3VWDT71K75M625420 Mileage: 217250km/134992miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: Malfunction 1010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Sporadic communication error 1000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Sporadic communication error 1000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: Sporadic communication error 1000
Address 01: Engine Labels: User\038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: RC s01b EDC G000DG 7551
Revision: --H01--- Serial number: VWZ7Z0E1675763
Coding: 0050078
Shop #: WSC 02580 444 64488
VCID: 64CD40ECDEDD
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 042 H HW: 02E 927 770 AD
Component: GSG DSG 041 0905
Revision: 04004010 Serial number: 00000501140114
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 1835241C5215
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021122
Shop #: WSC 00066 000 00000
VCID: 3A71DE940CD9
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AG
Component: ClimatronicPQ35 066 0505
Shop #: WSC 00000 000 00000
VCID: 6CDD28CC360D
3 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
004 - No Signal/Communication - Intermittent
01317 - Control Module in Instrument Cluster (J285)
00457 - Control Module for Network (J519)
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 C HW: 1K0 937 049 C*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000000014901
Coding: F4098E02400418000014000000140000002077035C
VCID: 2F67FFC0C79B
Part No: 1K1 955 119 B
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
Part No: 1K0 955 559 M
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 00000
7 Faults Found:
00526 - Brake Light Switch-F
008 - Implausible Signal - Intermittent
02071 - Local Databus
01332 - Door Control Module; Passenger Side (J387)
01320 - Control Module for Climatronic (J255)
01800 - Light Switch (E1)
01331 - Door Control Module; Driver Side (J386)
00483 - Control Module for Auxiliary Air Heater
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0060
Revision: 00000000 Serial number: AUZ4Z7D4021541
VCID: 2B5FEBD0F383
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD0179M$
Coding: 0012627
VCID: 2E59E2C4C091
Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AC HW: 1K0 953 549 AC
Component: J0527 010 0045
Coding: 0012041
VCID: 73EF33B06B33
Part No: XXXXXXXXXXX
Component: E0221 007 0050
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 971 D
Component: KOMBIINSTRUMENT 3HL 2120
Coding: 0023203
Shop #: WSC 08305 993 56004
VCID: 2C5DE8CCF68D
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 27001051100A7C
VCID: 295311D8F97F
6 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 82
Reset counter: 8
Mileage: 214810 km
Time Indication: 0
Date: 2000.00.00
Time: 20:35:07
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:05
00484 - Vehicle Position Recognition Control Module (J603)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:08
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 HW: 1K5 919 965
Component: Kompass 002 0001
Revision: 00002000 Serial number: 0371356TNPWV03
VCID: F8F5849CF255
1 Fault Found:
00926 - Terminal 30
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Mileage: 217221 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:11
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO 3HL 2120
VCID: 2C5DE8CCF68D
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 A HW: 3C0 959 760 A
Component: Sitzverstellung 0601
Revision: 00002000 Serial number: 00000000000000
Shop #: WSC 07342 444 52609
VCID: 2B5FEBD0F383
3 Faults Found:
00668 - Supply Voltage Terminal 30
01916 - Lumbar Support Fore / Aft Adjustment Sensor (G375)
011 - Open Circuit
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2339
Coding: 0001271
VCID: 3669CAA438C1
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.3 1502
VCID: 3065FCBCDAA5
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 13100F880106083F3F06050FA0080F0490A540
VCID: 8201E674A489
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Component: NGS n.mounted
Component: IRUE n.mounted
3 Faults Found:
00930 - Locking Module for Central Locking; Rear Left (F222)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01110011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 166
Mileage: 206558 km
Time Indication: 0
Date: 2000.00.00
Time: 13:07:58
Freeze Frame:
Fault Status: 00110010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 48
Mileage: 217221 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:25
00931 - Locking Module for Central Locking; Rear Right (F223)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 234
Mileage: 209557 km
Time Indication: 0
Date: 2000.00.00
Time: 14:38:19
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No: 1K6 035 456
Component: 08K Audioverst. 0003
Revision: 00002000 Serial number: 00000000018326
VCID: E9D3D1D8B9FF
1 Fault Found:
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit - Intermittent
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001271
VCID: 3777C7A03FCB
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 HW: 1K0 035 180
Component: Radio DE2 008 0115
Revision: 00008000 Serial number: VWZ4Z7E2018371
Coding: 0010010
VCID: DDBBF5087DB7
1 Fault Found:
01305 - Databus for Infotainment
014 - Defective - Intermittent
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2416
Coding: 0000144
VCID: 3163F9B8D1AF
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 3261F6B4D4A9
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5BE5C8CD97
End ---------------------------------------------------------------------
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Chassis Type: 1K0
72 7D
08-Auto HVAC -- Status: Sporadic communication error 1000
09-Cent. Elect. -- Status: OK 0000
Coding: 0050078
VCID: 64CD40ECDEDD
Coding: 0000020
VCID: 1835241C5215
Coding: 0021122
VCID: 3A71DE940CD9
VCID: 6CDD28CC360D
VCID: 2F67FFC0C79B
Coding: 00065493
Shop #: WSC 00000
Coding: 00217125
Shop #: WSC 00000
VCID: 2B5FEBD0F383
Coding: 0012627
VCID: 2E59E2C4C091
1 Fault Found:
Coding: 0012041
VCID: 73EF33B06B33
1 Fault Found:
Coding: 0023203
VCID: 2C5DE8CCF68D
VCID: 295311D8F97F
6 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 82
Reset counter: 8
Mileage: 214810 km
Time Indication: 0
Date: 2000.00.00
Time: 20:35:07
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:05
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:08
VCID: F8F5849CF255
1 Fault Found:
00926 - Terminal 30
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Mileage: 217221 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:11
VCID: 2C5DE8CCF68D
VCID: 2B5FEBD0F383
3 Faults Found:
011 - Open Circuit
Coding: 0001271
VCID: 3669CAA438C1
VCID: 3065FCBCDAA5
1 Fault Found:
000 - -
VCID: 8201E674A489
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 166
Mileage: 206558 km
Time Indication: 0
Date: 2000.00.00
Time: 13:07:58
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 48
Mileage: 217221 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:25
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 234
Mileage: 209557 km
Time Indication: 0
Date: 2000.00.00
Time: 14:38:19
VCID: E9D3D1D8B9FF
1 Fault Found:
Coding: 0001271
VCID: 3777C7A03FCB
Coding: 0010010
VCID: DDBBF5087DB7
1 Fault Found:
Coding: 0000144
VCID: 3163F9B8D1AF
Coding: 0000144
VCID: 3261F6B4D4A9
VCID: 2D5BE5C8CD97
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 19: DTCs cleared
Address 1C: DTCs cleared
Address 36: DTCs cleared
Address 44: DTCs cleared
Address 46: DTCs cleared
Address 47: DTCs cleared
Address 56: DTCs cleared
VCID: 295311D8F97F
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 8
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 03:07:01
long coding central conv.
new coding
13100F880106083F3F06050FA0080F0490A5C0
It appears that one or more of the modules will not let the system go into sleep mode and therefore continues to use power all night draining the battery
Any ideas?
VCID: 295311D8F97F
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 8
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 03:07:01
And
Chassis Type: 1K0
72 7D
Coding: 0050078
VCID: 64CD40ECDEDD
Coding: 0000020
VCID: 1835241C5215
Coding: 0021122
VCID: 3A71DE940CD9
VCID: 6CDD28CC360D
3 Faults Found:
VCID: 2F67FFC0C79B
Coding: 00065493
Shop #: WSC 00000
Coding: 00217125
Shop #: WSC 00000
7 Faults Found:
VCID: 2B5FEBD0F383
Coding: 0012627
VCID: 2E59E2C4C091
1 Fault Found:
Coding: 0012041
VCID: 73EF33B06B33
1 Fault Found:
Coding: 0023203
VCID: 2C5DE8CCF68D
VCID: 295311D8F97F
6 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 82
Reset counter: 8
Mileage: 214810 km
Time Indication: 0
Date: 2000.00.00
Time: 20:35:07
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:05
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:08
VCID: F8F5849CF255
1 Fault Found:
00926 - Terminal 30
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Mileage: 217221 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:11
VCID: 2C5DE8CCF68D
VCID: 2B5FEBD0F383
3 Faults Found:
011 - Open Circuit
Coding: 0001271
VCID: 3669CAA438C1
VCID: 3065FCBCDAA5
1 Fault Found:
000 - -
VCID: 8201E674A489
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 166
Mileage: 206558 km
Time Indication: 0
Date: 2000.00.00
Time: 13:07:58
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 48
Mileage: 217221 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:25
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 234
Mileage: 209557 km
Time Indication: 0
Date: 2000.00.00
Time: 14:38:19
VCID: E9D3D1D8B9FF
1 Fault Found:
Coding: 0001271
VCID: 3777C7A03FCB
Coding: 0010010
VCID: DDBBF5087DB7
1 Fault Found:
Coding: 0000144
VCID: 3163F9B8D1AF
Coding: 0000144
VCID: 3261F6B4D4A9
VCID: 2D5BE5C8CD97
Chassis Type: 1K0
72 7D
Coding: 0050078
VCID: 64CD40ECDEDD
Coding: 0000020
VCID: 1835241C5215
Coding: 0021122
VCID: 3A71DE940CD9
VCID: 6CDD28CC360D
VCID: 2F67FFC0C79B
Coding: 00065493
Shop #: WSC 00000
Coding: 00217125
Shop #: WSC 00000
VCID: 2B5FEBD0F383
Coding: 0012627
VCID: 2E59E2C4C091
1 Fault Found:
Coding: 0012041
VCID: 73EF33B06B33
1 Fault Found:
Coding: 0023203
VCID: 2C5DE8CCF68D
VCID: 295311D8F97F
6 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 82
Reset counter: 8
Mileage: 214810 km
Time Indication: 0
Date: 2000.00.00
Time: 20:35:07
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:05
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 48
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:08
VCID: F8F5849CF255
1 Fault Found:
00926 - Terminal 30
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Mileage: 217221 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:11
VCID: 2C5DE8CCF68D
VCID: 2B5FEBD0F383
3 Faults Found:
011 - Open Circuit
Coding: 0001271
VCID: 3669CAA438C1
VCID: 3065FCBCDAA5
1 Fault Found:
000 - -
VCID: 8201E674A489
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 166
Mileage: 206558 km
Time Indication: 0
Date: 2000.00.00
Time: 13:07:58
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 48
Mileage: 217221 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:25
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 234
Mileage: 209557 km
Time Indication: 0
Date: 2000.00.00
Time: 14:38:19
VCID: E9D3D1D8B9FF
1 Fault Found:
Coding: 0001271
VCID: 3777C7A03FCB
Coding: 0010010
VCID: DDBBF5087DB7
1 Fault Found:
Coding: 0000144
VCID: 3163F9B8D1AF
Coding: 0000144
VCID: 3261F6B4D4A9
VCID: 2D5BE5C8CD97
VCID: 295311D8F97F
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 8
Mileage: 217259 km
Time Indication: 0
Date: 2000.00.00
Time: 03:07:01
new coding
Any ideas?
