Jesus Is Lord
- Joined
- Jan 24, 2014
- Location
- Hersey, MI
- TDI
- 2005 Passat TDI Wagon 144,000 2003 Eurovan VR6 2007 Touareg V10 TDI 158,000
My dad and I were driving a Ford 7.3l powerstroke pulling a trailer. When we were going up a hill in sixth gear at 1600 RPM (which is maximum torque for that engine) we could not maintain speed. But if we downshifted to fifth, we could accelerate.
My dad asked me how we could accelerate when we were making less torque. I knew it had to do with RPM but could not get over the fact that we were making less torque. We were making more HP. And I had to admit the engine was making more "power".
I started doing research and found a lot of interesting stuff.
-Torque is a measurement of force and does not necessarily move anything.
(you can put 500 ft lbs of torque on a bolt and it might not ever move)
-HP is a measurement of power
(1 HP is the power needed to move 33,000 ft lbs one foot in one minute)
-The key to HP is that it takes into account time
-200 ft lbs of torque at 200 rpm is a lot less power than 200 ft lbs of torque at 400 rpm
So I found that torque is used to calculate HP based on RPM but is not a measurement of power.
(1 HP = Torque x RPM / 5252)
So an engines peak torque is basically useless in measuring an engines power.
Now I know what you all are thinking, why does a diesel car with less HP win a race against a gas car with far more HP?
A diesel creates its torque very early in its rpm range so that its average HP is higher over its RPM range than most gas engines.
A gas engine that creates 1000 HP at 7000 RPM may have a very low average HP.
But a diesel that only creates 750 HP may create enough HP at low RPM to make its average HP higher than the gas engine.
