Old March 8th, 2019, 17:44   #1
mobrien23
Default Engine Temp Gauge - increase past 190 F
2013 Passat TDI - NMS - 275,620 miles - engine temp gauge moves past 190 but never goes up to 260 - dealer can't find any issues with cooling system - no codes for temp change -
Also - 2-3 hour drive - Red adblue light turns on saying no restart - kept driving - light goes out and code resets after 2 days - dealer has not ideas beside explore wire harnesses at $110/hour -search - not sure what to do - any ideas?
-Spent $320 on 2 shops to diagnosis problem - none found
mobrien23 is offline   Reply With Quote
Old March 11th, 2019, 05:35   #2
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 3.3 Mi/kWh
How hot is it getting? The 12-14 Passat TDIs have a 220*F thermostat. Under high load conditions it's "normal" to see the temp gauge start to move. I think the highest temp we saw on ours was 226*F.
-J
Present:
2018 Tesla Model 3 DM. 50,000 miles.
2014 Cadillac ELR. 38,000 miles.
2013 Fiat 500e. 32,000 miles.
1991 Mercedes 350SDL 230,000 miles, 70,000 on engine. 18/27 MPG.
Past:
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG. Sold to JDSwann's Brother.
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
1988 Audi 5000S Quattro, 1992 Jetta ECOdiesel, 1991 Jetta ECOdiesel.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Check out the official TDIClub Chat Room!
Originally Posted by BRUSSELS BELGIAN View Post
Maybe I should pay MYSELF to do bad work on my car!
compu_85 is offline   Reply With Quote
Old March 11th, 2019, 05:37   #3
oilhammer's Avatar
Fuel Economy: fantastic
You are not alone with the DEF light deal, there seems to be a glitch in the new software and I am not sure yet they've figured it out. Many have given up and deleted the problematic system, which sucks, but...
www.cardocautomotive.com
Old March 12th, 2019, 19:55   #4
mobrien23
Temp gauge moves 4 hash marks past 190 on uphill climb - levels back to 190 on downhill and idle - 2 hash marks on highway drive after 30 minutes - temp has not moved past 190 in car history until 2017 - been doing it for 2 years - no shop has an answer or will to offer fix -
Old March 13th, 2019, 03:21   #5
oilhammer's Avatar
Yep, you'll soon find out why deletes are becoming so popular.
Old March 13th, 2019, 04:55   #6
740GLE
I'm guessing clogged coolant system components, not sure if even a DPF delete would solve that, as it'd just remove some of the heat the system needs to dissipate.
While heater cores are common replacement items, not sure if anyone had to change out radiators but I wouldn't be surprised if its clogged to some degree as well.
Hers: 2015 Passat SEL (NOS) w/ VW fix and Malone Stage 2 (low torque for DMF shudder).
Old March 13th, 2019, 05:57   #7
compu_85
Gadget Guy
compu_85's Avatar
A delete might lower the temp load some, but it won't change the 210*F thermostat, or the defective heater cores that gunk up the system. It might help with coolant breakdown in the EGR cooler, though.
-J
Present:
Past:
Old March 13th, 2019, 17:47   #8
mobrien23
DEF Light red - out of ad blue - no engine restart - Codes P204F & P20EE - Dealer advised catalytic converter (rear) is cause of Red Def light error - $865 to replace & solve problem
Old March 14th, 2019, 11:34   #9
fredthe
Um, have you had the mod? The catalytic converter is a named covered component.
Also did the light come on at high speed in cold weather? Same happened to me but I haven't taken it in yet.
-Fred
fredthe is offline   Reply With Quote
Old March 14th, 2019, 17:17   #10
mobrien23
I had the mod- they did not replace the catalytic converter - mileage at 276K now - light came on at highway speed in cold weather - dealer said computer scan showed a 45mph average speed - I am asking VW to cover the cost of the catalytic converter - no luck so far
Old March 15th, 2019, 04:23   #11
740GLE
so you had the emissions modification per the EPA agreement, are you still within the mileage of the extended warranty?
If so keep pointing to that warranty and tell them to pound sand.
Old March 15th, 2019, 10:35   #12
fredthe
The extended warranty post mod is 48K, and covers the cat. But I expect you may be past that.
Old March 21st, 2019, 16:45   #13
06bluebeetletdi
It is 51k for the 12-14 passats.
06bluebeetletdi is offline   Reply With Quote
Old March 22nd, 2019, 06:39   #14
mobrien23
Had the mod done at 206K and now at 277K - VW said out of warranty and no good "will" will be offered
Old March 22nd, 2019, 13:30   #15
Lex Tdi
TDI(s): 2013 Passat
Delete sounding better but guessing that would be caught in NY with emissions test?
2013- Passat SE DSG 190,000 miles
RIP 2003 Jetta - 444,000 miles
SOLD 2001 Jetta - 300,000 miles
Thanks to Paramedick (Bruce) for being my local Guru for over a decade!
Lex Tdi is offline   Reply With Quote
Increase in engine temp with cell phone plugged in smDuck25 General VW Discussion 1 August 7th, 2015 04:37
code 'high temp' but gauge is normal 190 gdoine OBD Scanners 3 March 6th, 2010 12:22
TEMP GAUGE PAST 190 DEGREES? STRANGETDI TDI 101 5 June 23rd, 2003 18:54
Temp gauge is above 190 Turbo D TDI 101 8 September 11th, 2002 15:10
When temp gauge hits 190, is engine fully warmed? OffTheFence VW MKIV-A4 TDIs (VE and PD) 6 November 7th, 2001 18:56
Page generated in 0.19811 seconds with 13 queries
[Output: 129.44 Kb. compressed to 108.38 Kb. by saving 21.05 Kb. (16.26%)]
