Old May 20th, 2020, 15:12   #76
TejGhost
I Powdercoated my intake manifold and Valve Cover @holdndown1bae on insta if you want this done to yours as well ;-)
Sent from my Note9
TejGhost is offline   Reply With Quote
Old May 26th, 2020, 17:03   #77
mjez
TDI(s): 00 Jetta
Fuel Economy: 47mpg
Sold it.
I have original busted CV axle if anyone wants to rebuild it. I'm in far north suburbs of Chicago, closer to Wisconsin border, come and get it.
Sent from my PH-1 using Tapatalk
mjez is offline   Reply With Quote
Old May 28th, 2020, 19:17   #78
hooville
hooville's Avatar
Fuel Economy: 43.2 lifetime average!
The MK4 has been getting all the love in the second act of the Pandemic: I replaced the OEM Cassette player & Phatnoise with a DD Sony with CarPlay, hands free calling and a backup camera. The stock speakers sound so good now that we're going to keep them for a while longer!
Replaced the tail light bulbs while I was installing the camera and license plate bracket.
Upgraded the glove box to the larger version and FINALLY got around to removing the remaining soft touch paint on the dash and door handles. I still have to clean it off the armrest but now i can touch the dash without getting sticky black residue on my hands and clothes.
Installed lighted Jetta vents but somehow lost one of the wiring harness pigtails in the shuffle so the passenger vent illumination is on hold until the next trip to the pull-a-part.
White 2015 Sportwagen S TDI - MIB2
White 2016 GTI S - A Few Discrete Mods Here & There...
Silver 2000 Golf GLS TDI - CAT 2 Filter, Shine Real Street Suspension, Bilsteins, RC3, Nozzles
hooville is offline   Reply With Quote
Old May 29th, 2020, 18:09   #79
pkhoury
That guy with the goats
pkhoury's Avatar
They have a larger version of the glove box? Hopefully that version also means one where the door latch works!
And isn't that soft touch paint awful? I'm going to venture to guess your car has a black interior?
2013 JSW 02Q - Malone Stage 3, CR170, rawtek 3" straight pipe, PolarFIS, Panzer plate, front fogs, Bosal towhitch, Neuspeed 28mm swaybar, Sachs racing clutch, Peloquin LSD, dieselgeek shortshifter, CP3
2004 Golf GLS 02J - Malone Stage 4, VNT17, DC Stage 2 clutch, darkside 2.5" downpipe/intercooler/TIP MFA cluster swap
2003 Jetta GLS 01M - EGR cooler delete, Melett VNT17, Darkside SMIC. Future Ute/02J project
pkhoury is offline   Reply With Quote
Old May 30th, 2020, 21:31   #80
Nuje
Nitrile gloves, oven cleaner, green ScotchBrite pads - makes short work of that soft-touch crraaaaap.
His ride: 2015 GSW SEL TDI with MIB2, Active Info Display, Adaptive Cruise retrofit
Her ride: 2016 A3 e-tron
His other ride: 2015 Giant Propel SL Di2
Nuje is online now   Reply With Quote
Old June 1st, 2020, 11:17   #81
hooville
hooville's Avatar
Black interior indeed! I used TSP and a non-scratch sponge to clean it off: the first door handle I cleaned got scratched up pretty well with ScotchBrite so I switched scrubbers. It looks smoother but it takes longer to remove. I'm going to try oven cleaner when I tackle the armrest!
I upgraded to the larger one because my wife doesn't travel light...
It's not difficult to do: remove glove box and the metal braces from behind, change the connector for the new light and you're done. The hardest part was removing the lock cylinder to put the old one in so the locks would match. It has the same latch.
I pulled the old glove box out a few years ago to fix the right hinge that had been broken for a good while and cleaned the soft touch off while it was out. MUCH easier to clean than in the car!
Old June 1st, 2020, 12:24   #82
Nuje
For around $30USD, you could instead, totally bling it up!
https://www.aliexpress.com/item/4000890120666.html
Old June 2nd, 2020, 04:21   #83
Dannyboy
TDI(s): 2014
I feel your pain! I'm trying to get my 2010 JSW ready to list it for sale, as I'm more than happy with just an ALH, BEW and CJAA (best of all three worlds).
Nearly the same, ALH , BRM and CJAA. Might get rid of the ALH, seems to be cursed and definitely doesn't want to be fixed. Either that or a second ECU is bit the dust.
Dannyboy is offline   Reply With Quote
Old June 2nd, 2020, 04:41   #84
JETaah
Fuel Economy: 53 max, 42 min, average 46
I didn't do anything to my own TDIs other than get the insurance taken off of them. All the sheltering has lessened the need for more than one vehicle between the wife and myself. Gas is cheap....what can I say. The Sorento is a better fit for her, too.
On the other hand, I have not run short of TDI work for others. While owners are not working, it is a good time for them to get caught up with needed repair and maintenance.
1999.5 a4 Jetta, port matched, RC2, sprint 520's, 1.5" lift kit
1996 Passat B4V, coat hanger supported exhaust system,
Visit me www.martinbergelllc.com
JETaah is online now   Reply With Quote
Old June 3rd, 2020, 15:04   #85
Nuje
Originally Posted by DzoniS View Post
I finally managed to get an aftermarket Carplay in my VII.
The installation went smoothly and everything works like it should for now.
I've used this tutorial as it has pictures and everything if anyone else needs help *SPAM Link removed*
Can you post the installation instructions they gave you? I'm curious as to exactly what gets installed where and how. The page on their blog makes me ask more questions than it provides answers.
How long did it take for the unit to arrive to you in "United States" (which state)?
What trim is your car?
Will this work in a car with Fender Premium audio?
Old June 8th, 2020, 14:49   #86
Stopx
TDI(s): A3 Cbbb
Fuel Economy: 41mpg avg.
I've changed my EGR valve on hot eingine not a smart move .
Stopx is offline   Reply With Quote
Old June 9th, 2020, 17:05   #87
Black00Jetta
Black00Jetta's Avatar
Fuel Economy: 51.1/45.2/39.6
Did an oil/filter change (310k), replaced the 2 gaskets to the oil filter cooler (had an oil leak up north when temp dropped to 10 degrees last Oct.) and tightened passenger side drive shaft bolts (changed that about 7 years ago). 3 were finger tight and 3 were out about 2-3 revolutions. Dodged a bullet on that one. One reason why I rotate oil changes from topside to crawling underneath and checking underside!
2000 Jetta GLS TDI 5spd manual, 299k[/SIGPIC], chipped, Frost heater, metal skid plate, Metalnerd brake tool, ventectomy, VCDS(but need to learn how to use it). Scangauge II
Black00Jetta is offline   Reply With Quote
Old June 9th, 2020, 21:00   #88
Nuje
Spent a couple hours trying to get new (to me; definitely used) 3B0920847E cluster IMMO-matched to my 2003 Golf.
No luck yet.
Old June 10th, 2020, 22:23   #89
Nuje
No luck yet.
Note to self: Remember that you're old, and your memory - which used to be pretty good with numbers...not so good-like anymore.
Discovered that the issue with mating the new (to me) FIS cluster to my 2003 Golf was that I was using what I was *sure* was 8121 was the original PIN.
WRONG!
Used the proper one, and 10minutes later, everything's good.
Brought it home today.... Webbie1 VW Passat Family (NMS and B7) TDIs (2012+) 18 June 3rd, 2019 06:34
Brought it home today.... Webbie1 VW Passat Family (NMS and B7) TDIs (2012+) 0 May 4th, 2019 17:30
I got my TDI home today fungi131 VW MKIV-A4 TDIs (VE and PD) 2 March 20th, 2011 13:14
Came Home On the Hook TWICE Today! CMB430 VW MKV-A5 Golf/Jettas 19 February 17th, 2011 17:23
Brought It home Today!! Dezelduber VW MKIV-A4 TDIs (VE and PD) 6 October 19th, 2000 17:48
Page generated in 0.16367 seconds with 11 queries
[Output: 129.23 Kb. compressed to 109.03 Kb. by saving 20.20 Kb. (15.63%)]
