Old April 11th, 2020, 19:25   #46
DivineChaos
i washed and waxed it. apon waxing i realised that i have to clay bar it and buff the paint out. found a chip in the drivers door and a lot of surface rust spots. (caused my bits of metal contamination in the clearcoat) cleaned the interior and while cleaning the rear seats i noticed a broken thread in a seam causing it to seperate. (yeah im pretty thorough) I think my daughter might have picked at it at some point. not sure. So i got to contact my leather guy and see if he can fix it. The cornsilk beige cleans easily. Debating if i should change the fuel filter...
DivineChaos is offline   Reply With Quote
Old April 12th, 2020, 14:56   #47
Cptcrnch
Replaced the driver side wing mirror cap. There were some crazy high wind gusts on my way home from work Friday morning and the cap came straight off. Made quick drive out to my local U-pull-it junkyard and got a mirror cap off another TDI wagon. Most of the good stuff was already pulled off the motor and it was an automatic so I didn’t bother grabbing anything else.
Cptcrnch is online now   Reply With Quote
Old April 29th, 2020, 21:15   #48
pkhoury
That guy with the goats
pkhoury's Avatar
Since this thread has gotten quiet...
I ran over a mattress a week and a half ago in my '04 Golf. Got enough money to buy some upgrades for my ALH (like a VNT17). Also discovered I have a blown exhaust manifold gasket in the Golf, so I took off the turbo and studs today, to replace with new studs, gasket and nuts tomorrow, assuming everything arrives on time.
2013 JSW 02Q - Malone Stage 3, CR170, rawtek 3" straight pipe, PolarFIS, Panzer plate, front fogs, Bosal towhitch, Neuspeed 28mm swaybar, Sachs racing clutch, Peloquin LSD, dieselgeek shortshifter, CP3
2004 Golf GLS 02J - Malone Stage 4, VNT17, DC Stage 2 clutch, darkside 2.5" downpipe/intercooler/TIP MFA cluster swap
2003 Jetta GLS 01M - EGR cooler delete, Melett VNT17, Darkside SMIC. Future Ute/02J project
pkhoury is offline   Reply With Quote
Old April 30th, 2020, 16:40   #49
Seatman
Seatman's Avatar
Fuel Economy: No idea
Last thing I did was a last week, timing belt. Car is a 2007 Seat Alhambra 2L tdi
[/IMG]
No idea how to add pics from your gallery but feel free to browse lol
Seatman is offline   Reply With Quote
Old April 30th, 2020, 16:57   #50
Nuje
I don't know how many hundreds or thousands of your posts I've seen on this board, Seatman, but I just realized now that you probably go by "Seatman" here because....your car is a Seat.
(Takes me a while, but eventually I get there. )
His ride: 2015 GSW SEL TDI with MIB2, Active Info Display, Adaptive Cruise retrofit
Her ride: 2016 A3 e-tron
His other ride: 2015 Giant Propel SL Di2
Nuje is offline   Reply With Quote
Old April 30th, 2020, 17:38   #51
aslspiderman
aslspiderman's Avatar
TDI(s): 98 Jetta
Fuel Economy: Really good!
Washed and waxed. Pulled front seats and replaced all the plastic bits. Now they can move back and forth.
98 Jetta, K03/04, 520 sprints, aligator chip, SRS, torsion bar, Billy HD's, TT bushings VR6 clutch, GLX seats
aslspiderman is offline   Reply With Quote
Old April 30th, 2020, 19:50   #52
pebjr
Finally had the opportunity to replaced the driver side door lock mechanism on my 09 Jetta..
pebjr is offline   Reply With Quote
Old May 1st, 2020, 07:07   #53
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
This afternoon, I get to pull off the left front tire and wheel liner to try to fix the running light. Last year, some butthead neighbor backed into the front corner and popped the light into the fender well. Dealer tried to fix it when it was in for a CEL under the extended warranty.
2010 silver/black JSW TDI with DSG, 2017 Ram 1500 EcoDiesel
kjclow is offline   Reply With Quote
Old May 1st, 2020, 09:31   #54
mjez
TDI(s): 00 Jetta
Fuel Economy: 47mpg
Replaced what I thought to be a bad bearing only to find out that my CV joint is busted. Now trying to decide where to get a new CV/half-shaft from... Hmmm
Sent from my PH-1 using Tapatalk
mjez is offline   Reply With Quote
Old May 1st, 2020, 11:14   #55
Powder Hound
Powder Hound's Avatar
Use IDParts to get a new CV joint, replace that and motor on. Buying a new chinesium halfshaft from your FLAPS is about the most expensive thing you can do. Why? Because it will not last, may (if it is the long side) be out of balance causing harmonic vibrations that are unexplainable, and it will cost you more time and money to replace it after it breaks.
In all seriousness, don't throw out your old one, fix it instead.
Cheers,
PH
Old May 1st, 2020, 13:53   #56
Hyde7278
Hyde7278's Avatar
TDI(s): 2001 Golf GL
Cheers,
PH
+1
Just replace the cv joint with a quality aftermarket part
Hyde7278 is offline   Reply With Quote
Old May 1st, 2020, 17:01   #57
mjez
TDI(s): 00 Jetta
Fuel Economy: 47mpg
Originally Posted by Hyde7278 View Post
+1
What do you recommend? I honestly only want to fix it to sell it. I just got replacement oil burner for my tdi. Unless someone here wants it cheaper to fix it. I've thrown bunch of parts at it recently.
Old May 2nd, 2020, 02:03   #58
pkhoury
pkhoury's Avatar
If you get the replacement axle from idparts, it's like 80 bucks. I was curious how it worked and took the ball bearings out (don't do that). That aside, it's maybe a 1-2 hour job changing the boot/axle, and probably your cheapest option. Sure, you can get some cheap Chinese crap for the same price, but nobody knows how long it'll last.
Old May 2nd, 2020, 17:06   #59
turbobrick240
turbobrick240's Avatar
Not exactly tdi related, but I got my "new" 1600cc dune buggy running great today. Some crap had plugged the fuel inlet on the carb. I haven't had this much fun with a vehicle in a long time. Took me a while to figure out reverse- not sure why, my more modern VW's require pushing down on the gear knob to engage reverse too.
turbobrick240 is online now   Reply With Quote
Old May 2nd, 2020, 18:04   #60
BMAN
Fuel Economy: BMAN
Painted my calipers and installed my new BBS wheels
BMAN is offline   Reply With Quote
Brought it home today.... Webbie1 VW Passat Family (NMS and B7) TDIs (2012+) 18 June 3rd, 2019 06:34
Brought it home today.... Webbie1 VW Passat Family (NMS and B7) TDIs (2012+) 0 May 4th, 2019 17:30
I got my TDI home today fungi131 VW MKIV-A4 TDIs (VE and PD) 2 March 20th, 2011 13:14
Came Home On the Hook TWICE Today! CMB430 VW MKV-A5 Golf/Jettas 19 February 17th, 2011 17:23
Brought It home Today!! Dezelduber VW MKIV-A4 TDIs (VE and PD) 6 October 19th, 2000 17:48
Page generated in 0.19393 seconds with 11 queries
[Output: 129.76 Kb. compressed to 108.62 Kb. by saving 21.14 Kb. (16.29%)]
