dst5
Ford does JIT now to all major company's do that if they want to be competitive.
Just like not all of the rest of the CRs will need an HPFP tomorrow, but that doesn't mean there isn't an issue there... No one said the sky was falling, but completely dismissing the issue sounds like something VW would do (not Fred's community).Not that VW has a massive problem with turbos and all of our Passats will need a new turbo in the next few days.
I'd say your entire post is, well, VERY serious. You're correct, all of us here DO take what people say very seriously, especially when the statement is as extreme as your opening sentence above.So if the turbo really is gone (and twice now), then VW has yet another serious issue on their hands with the Passat's CR engine... Twice now they've dropped the ball on the CR, first on the HPFP and now on the turbo. What's next?
I wonder what the chances of a runaway on the new Passat when the turbo blows? I'd rather face an HPFP failure with the car dying on the side of the road than a runaway engine from a blown turbo any day of the week.
I was today at ny VW dealer and asked service manager about turbo failures, he said that he didn't for long time on new or newer VW Jetta, GTi, Passat combine.
Can't be that risky or there would be some sort of alarm going off to alert you to it.Bottom line, physics dictates that turning off the engine in the middle of an active regen is risky business. I'm not saying that is the cause of the aforementioned turbo failures - who knows.
I'm not sure if I would make such a blanket statement, while you might be right, it isn't a bad idea to let the engine cool or complete a cycle, it certainly isn't going to harm anything.Can't be that risky or there would be some sort of alarm going off to alert you to it.
Regards
I might look into that, I'm already trying to twist the dealers arm behind their back on the trade and getting the Passat's price down by $1000 so I might just have to deal with it. I wish I would have checked to see if it had the Michelins when I took it out for the test drive two weeks ago....duhh...I just re-read your post. You never said temps go up TO 500-600f, but go up 500-600 ABOVE normal EGTs. Sorry about that.
Good luck with your purchase. I would recommend you make sure the tires on the car are compatible with the road surfaces around Austin. The OEM Hankooks are very noisy on anything but smooth road surfaces, and some dealers are willing to swap them out.
Your trading off your Mustang GT for a Passat! Do you need the 4 doors and a back seat I imagine? I am thinking the new ford taurus sho looks like a nice car.Thanks TDI, I'm actually hoping to pick up a TDI SE with NAV next Friday if the numbers are right. Sad those as it means saying goodbye to my 2013 Mustang GT Premium
If your info is correct then my numbers are just a little off and the difference in your car between regen and normal operation is actually closer to 600 degrees. I know the systems are quite different, I just wanted to paraphrase my current understanding of the newer technology. Even with the big trucks people who used them as grocery getters without ever putting the engines under load (towing) often experienced some of the same problems with the engine not getting hot enough to burn off waste in the exhaust system and turbo.
Too bad VW didn't install heat extractors on the hoods like they have on the Mustang. Guess that would have looked way to aggressive on a family sedan.
And I stayed at a Holiday Inn Express last night.I talked to my friend, he has shop and about 35 years of experience in the car racing, so he told me the conventional oil would burned and crystallize, becoming sharp and harder the metal, so it would eat the bearing, now days with synthetic oil, it does not happen anymore, so cooling turbo is good thing to do but unnecessary.
