They can buy it, but not the general public aka shade tree mechanics.Asl6 said:oky doky i'll pass this info on. i just hope they'll do the job right though i won't hold my breath!
Well first off a set of gauges that measure both high and low sides is more helpful than that. Second the pressures will vary depending on ambient temp, humidity and compressor speed which on most vehicles is directly tied into the RPM.MAXRPM said:
Open the valve on the can and let a little refrigerant into the system, then close the valve on the can. Note the pressure reading and wait 5 minutes. Make sure the pressure doesn't drop, although it may go up. If it goes down, you have a leak. Luckily, I did not. If there are no leaks, allow the oil charge into the system by turning the can upside-down. Now, get another can of refrigerant, pierce the top, and install to the lowside connector. Start the car and turn on the AC.
Open the can of ec-12a refrigerant and allow it into the system, slowly. Turn the can upside down, but not all at once - a little bit at a time. It will take the whole can. Check your pressure. Mine was about 35 psi.
It will probably take about another 3-4 ozs from a second can. DO NOT use the whole second can. It is too much.
When you hook up this tester to the car and measure the 35psi, do you do it with the A/C on and the car running or the car turned off? sorry for my ignorance.
I am all for using the right stuff. I saw this chart on their web page and does it imply that 134A is also flamable with a lower auto ignition temperature??Bad idea to use R12a. The "envirosafe" stuff is nothing but propane and butane. If it was that good, why wouldn't VW put in into the cars from the factory? Think huge fireball if you get into a front end collision when all the refrigerant excapes.
Google it if you don't believe me. I would rather use old CFC's that have yet to have proof that they are causing ozone destruction than use clearly flammable refrigerant which can KILL people in a accident. Why do you think they add "pine" scent to it?
Personally, I would use the CORRECT R134A which these cars is designed for.
Liability, plain and simple. The idea of having flammable gas in a car where people might be smoking can be a liability. If the evaporator should happen to leak and then igniteBad idea to use R12a. The "envirosafe" stuff is nothing but propane and butane. If it was that good, why wouldn't VW put in into the cars from the factory? Think huge fireball if you get into a front end collision when all the refrigerant excapes.
Anyone know where I can order just a compressor clutch for my compressor?As this is an old but authoritative thread on AC repair around the forum. I will add my experience. I bought the car knowing the AC didn't work at all. I noticed that the AC button didn't engage the compressor at all, but I bought it in the fall so have only started thinking about it recently. The PO told me he took it to a shop and they told him it was the compressor. I read this thread numerous times gearing up for the same job but something Herm TDI said elsewhere in the forums caught my attention. He mentioned the clutch coil going bad and its actually very easy to check. Simply take a Ohms/resistance reading on the compressor electrical plug and it should read about 4.0 but mine showed infinite. Just to be sure I tried to jump it and it still didn't engage so I had found at least one major problem.
You can get a new clutch coil for about $60 from Polar Bear Inc. and they are very helpful. The install is relatively very easy. Here is a tutorial to get you started but its pretty self explanatory.
The beauty of this fix is that you don't open the refrigerant side of the AC system saving lots of cash and time. My AC hadn't worked for a year or two and I had no knowledge of the possibility of leaks or the amount of refrigerant in the system. I replaced the coil and turned on the AC only to be pleasantly surprised by ice cold air. It works good as new now. Before you replace and open the system make sure this isn't your problem.
A big thanks to Herm for guiding me in this!
Here is a clutch coil...Anyone know where I can order just a compressor clutch for my compressor?
just purchased the denso one for $100 bucks, very good deal imhoWhat do you guys make of the remanufactured compressors on eBay? They don't seem much more expensive than a clutch kit. My bearing grenaded and we mangled the compressor shaft really good getting the clutch off. The clutch does not come off very easy on cars from Ontario, I can tell you that.
I've used the dye to find leaks with a black light. Cheaper liquid soap and a little water can be used to check the fittings and connections where it usually leaks. Be sure to wash off the soap mixture because it will corrode over time. If you have it charged with the HC-12 stuff I don't think an electronic detector will work.I have successfully used ES12a, but once when the system didn't require all of the last can, I removed the can tap and sparked the remaining gas that was coming out. What a mistake! I ended up running out of the garage with a blow torch in my hand as the flame shot out a foot or more. This was with a can that was almost empty. After experiencing this I can't take seriously the claims that ES12a is totally safe.
Loved this thread, although what I have now is a lowly antique 1985 Jetta diesel which I love and wife hates since left door was banged in from accident. AC used to work, but leaks so I need to find the leak. I'm not very happy with electronic leak detectors as i can't find the leak with the one I have. I think the UV type dye might work better (anyone have any experience with it?). My antique has about 150K miles on it, so diesel lovers would probably say it's just broken in. It still has the original coolant lines on it, so those German parts are pretty good.
Here's a tool that might be useful, a vacuum puller for the diy'er
http://www.harborfreight.com/air-vacuum-pump-with-r134a-and-r12-connectors-96677.html
