Old July 2nd, 2018, 22:56   #11041
TDI-WNC
Anyone live in a state where diesel is typically cheaper or the same price as regular unleaded? Here (NC) diesel is typically 30 - 50 more expensive. I have filled up in Tennessee a couple of times and diesel was 10 less than regular unleaded.
Why?
TDI-WNC is offline   Reply With Quote
Old July 9th, 2018, 05:03   #11042
Yourbuddysatin
Don’t you know??? Diesel is harder to refine compared to gasoline........
Yourbuddysatin is offline   Reply With Quote
Old July 9th, 2018, 05:56   #11043
romad
romad's Avatar
Why?
Years ago diesel used to be usually less than regular gasoline. However with the no sulfer mandate it is now more expensive to refine.
But consider this: a car using diesel can go 50 miles on a gallon so at $3.50/gallon it costs 7 cents per mile. Meanwhile the same model car with a gasoline engine only goes 30 miles on a gallon so its $3.00/gallon price means it costs 10 cents per mile or about 43% more to cover the same distance!
The fleet:
romad is online now   Reply With Quote
Old July 9th, 2018, 07:02   #11044
When I started driving diesels the price difference between diesel and gasoline (regular, not unleaded...yes, it was that long ago), was usually a few pennies. But that was also at a time when fuel prices in general were very volatile. Since then it fluctuates, but is usually about the same price or a little less than unleaded premium, at least here in the northeast.
Honestly I don't care. The fuel efficiency of diesels more than makes up for any historical price disadvantage, as romad has pointed out. And I don't want to drive gasoline cars regardless.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old July 9th, 2018, 09:44   #11045
Tom Servo
Tom Servo's Avatar
Fuel Economy: ~39 mpg :(
Diesel is usually around mid-grade here, at least during parts of the year.
Right now it's a bit more, kind of between mid and premium. Seems like over the last 10 years or so, the spread between grades of gasoline has really widened. I remember when every single station was a uniform 10 difference between grades. So if the Raceway sold regular unleaded for $1.299, mid would be $1.399 and premium would be $1.499. Nowadays, 15 is the low end and some stations like Shell are 30 or even 49 cents per gallon different. Since they don't post the mid and premium prices on signs anymore, I feel sorry for the folks whose car run on those grades, because they are getting hammered.
The Shell nearest me today at 4 am:
RUG - $2.649
MID - $3.139
PRM - $3.629
Diesel - $2.899 / $2.959 (credit)
Go down the road a mile, and the Circle K is selling premium for $3.129 and diesel is $2.929. As you can see, this makes making a blanket statement comparing higher grade gas and diesel prices here kind of difficult.
Prior to Memorial Day diesel was anywhere from $2.799 to $2.999. Now it's $2.929 to $2.999. The high end is holding tight to the three buck ceiling, but the low end has shrunk.
~Zach
alabama broadcast media page
Tom Servo is offline   Reply With Quote
Old July 12th, 2018, 19:51   #11046
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Fuel Economy: pending
3.99 -down 17 cents
1.9ZOOK is offline   Reply With Quote
Old July 14th, 2018, 09:27   #11047
flyingjay
Fuel Economy: 43 city, 54 hwy (imp.)
Here in the Vancouver, B.C. area, diesel is about 10 cents a liter cheaper, which works out to about 36 cents per US gallon cheaper. A few weeks ago, it was a much as 20 cents a liter cheaper.
flyingjay is offline   Reply With Quote
Old July 15th, 2018, 18:37   #11048
listerone
Fuel Economy: 52mpg (highway)
In summer diesel is usually between Regular and Mid Grade...in winter it's typically close to Premium.That's in Massachusetts where I buy most of my fuel.
Current: 2014 BMW 328d
Previous: 2011 MB E350 Bluetec
Previous: 2009 BMW 335d
listerone is offline   Reply With Quote
Old Today, 07:51   #11049
kjclow
In NC and SC, diesel is typically in the 15-25 cents per gallon higher than regular and less than midgrade. I consider that the same vehicle with a gas engine will get about 30% lower mileage. With regular around $2, that means diesel would have to be higher than $2.60 to be more expensive to run.
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
romad
Page generated in 0.23657 seconds with 11 queries
[Output: 91.52 Kb. compressed to 78.47 Kb. by saving 13.05 Kb. (14.26%)]
