06 jetta tdi to install cam pin.
fluxcore
ma.
06 jetta tdi
is there a hole in block to accept cam pin, about @ clock time @ 8:00 to 8:30 position
JETaah
mi 48836
Yes.
Make sure you take in consideration the the engine is tilted back.
It is around 8 oclock if the head was oriented parallel to the ground.
Ol'Rattler
PNA
2006 BRM Jetta
You don't need to buy a cam lock tool. Use a letter "A" (.234 inch) sized drill bit.
In the head, yes. Sometimes I use a mirror to see in there to get it close before putting the pin in, and occasionally will have to rock the engine back and forth to get it in place. I lock the crank afterwards, because once the cam is locked, you can loosen the three bolts on the sprocket and rotate the engine slightly if necessary to get the crank tool in place.
