Drivbiwire
Zehntes Jahr der Veteran
- Joined
- Oct 13, 1998
- Location
- Boise, Idaho
- TDI
- 2013 Passat TDI, Newmar Ventana 8.3L ISC 3945, 2016 E250 BT, 2000 Jetta TDI
coast in gear, this puts the engine into a mode called "Over-Run". It's simple the engines rpms are being sustained when the ECU sees the pedal at "0 Load" or Idle. Since rpms are above Idle rpm of 900 the ECU reduces fuel to 0 until the rpms approach within 300 or so rpm of 900, then the fueling slowly returns to achieve a smooth transition to normal idle rpm.
I would suggest to leave the car in gear until you slow to 1500 rpm, then shift. Another ideal is if you know you are coming to a complete stop, put the car in neutral and once you are around 10mph select first and leave it there until you resume your driving.
On off ramps, coasting in gear allows you to quickly cool the turbo down. This reduces the stress on the turbo and eliminates the need for cool down idiling. The less you idle these cars the better off you will be.
Your sticking with the 2500/3000 rule will serve you VERY well for the life of your car! It will reward you with low maintenance and less probability of driver induced problems.
Practice makes better, get out and just get used to the downshift. I know when my wife would transition from our old honda to the Jetta that she struggled with the downshifting, so no big deal.
DB
DB
