whitedog
Car came to me with low power. It had been to a shop and they did some troubleshooting, but I don't know what the results were. I know that they disconnected the MAF and the intake at the EGR valve and the downpipe. I know this because this is how he drove it to me.
I found that the turbo vanes were seized, so I put on a good, used hot side and the actuator works when doing output tests with VCDS. So that means the N75 is good as well.
After I put the turbo back on, it still had no power and it wouldn't rev past 2500 RPM. I don't know if it would have before the turbo.
MAF specified and actual are hitting 850.
I got to wondering about the downpipe and I sat in the parking lot with the pedal on the floor. Slowly the RPMs would climb. Eventually I was hitting 3700 RPM and she was spewing blue smoke.
I think I need to pop that downpipe back off and see if we have a restriction. It's like sitting there revving it has help blow out the crap in the exhaust.
So, lets say that we do have a restriction there. Other than modifying the exhaust system, how do you clean out the exhaust other than a Tony tune-up?
