Congrats on your TDI!speed185187 said:Thanks guys. I changed the tranny oil on Friday evening. It resembled the G52 fluid but it was very dark. No chunks or bits of anything in it . Filled it up with the Royal Purple (MityVac works great for filling) and shifting is very smooth. It slides into each gear nicely. I'm going to stick with this for a while and see how it does when I move back to Chicago this November. 1500 miles under diesel power so far and loving it. Oh yea, i filled up on friday too from a 1/4. I'm getting 45.7mpg. and that's with a lead foot playing with my first turbo. lol
Amsoil works best for me..AndyH said:Congrats on your TDI!
They say their 75W-90 is a replacement for G050 but the replacement for your car is the much lighter viscosity G052726. See the chart in post 90.
Yup - GL-4 AND GL-5.speed185187 said:It says it's GL-4 on the bottle and here on their web page
i'm not drawing conclusions based on the results below, but because it is my TDI, i will not be using Redline D4 (or MTL) in the future.Diesel Addict said:Yes I remember seeing your MTL UOA. You only did one, correct? It's possible that the MTL, given that it has a lot of ester in it, cleaned out some deposits left behind by the OEM oil. That's why, and I'm sure you'd agree, you need at least 2 UOA's on the same fluid before drawing conclusions.
Yup. New, my '01 had no hum, after putting in the G50 juice, it hums.TDInownow said:Okay, so given the date of the TSB, should I believe that there was G52 (synthetic) in my '03 Jetta from the factory, or G50?
Wondering if I'll start to experience the spider-gear hum now with the G50 in there. What exactly should I be listening for?
Yup and the spyder gear noise is not harmful, just annoying. Much like brake pad squeal is not usualy harmful.dieseldorf said:I think the "spider gear noise" issue is at the heart of the switch from G50 to G52.
Thanks.
Your transmission is in failure mode.LessIsMore said:Drained RL. MTL after 15K, and it came out quite blackened. It was still shifting well enough, but whine was excessive, and I became concerned about wear..
Why do you say this?LessIsMore said:Your brain is in failure mode.
Redline gear lubes will clean tranny very well and they appear black after short time. you can drain and refill but it is not really necessary. The thin G50 or whatever it is sounds like a good choice for winter and colder climates but I wonder how much protection offers to the bearings in the tranny.VWTDIBeetle said:Why do you say this?
Is there something you know about blackened lube?
If not then it is best to just listen...
As you probably already know when you look inside a VW 5 speed that was dissassembled, you will only see a small amount of metal on the magnet and the rest will be whistle clean.Dimitri16V said:Redline gear lubes will clean tranny very well and they appear black after short time. you can drain and refill but it is not really necessary. The thin G50 or whatever it is sounds like a good choice for winter and colder climates but I wonder how much protection offers to the bearings in the tranny.
the "black stuff" is surface corrosion from bronze parts. That corrosion will happen whether you use yellow metal safe gear oil or G50 or ATF. Using the wrong lube will just accelerate it.VWTDIBeetle said:As you probably already know when you look inside a VW 5 speed that was dissassembled, you will only see a small amount of metal on the magnet and the rest will be whistle clean.
So where is this black coming from when using the Redline? Worn metal gets caught on the magnet.
Black is found in the syncros through.. LOL
Please explain why there is no "black stuff" with the factory lube?Dimitri16V said:the "black stuff" is surface corrosion from bronze parts. That corrosion will happen whether you use yellow metal safe gear oil or G50 or ATF. Using the wrong lube will just accelerate it.
Are you pretending to be a smart a$$ ?
LOL
When I drained my factory lube @ 50,000 miles it was black. That was on 05 TDI 5sp Wagon. I was shocked, but color is a poor way to determine fluid performance. Only an analysis will shed light on the situation.VWTDIBeetle said:Please explain why there is no "black stuff" with the factory lube?
Does the "black stuff" indicate that Redline is damaging the transaxle?
Was the color unusual on removal?speed185187 said:Well.. I hate to admit defeat but the royal purple trans oil doesn't work very well in my car. The first 1000 miles were perfect, nice and smooth, hot or cold. Just after I got past the 2500 mile mark it started getting harder to shift into 2nd, 3rd, and 5th. Stoped by the dealer and bought G52 and went right back to drain and fill. Hit the road and wow, it feels like a totally different transmission. Much better. So my lesson learned. I'm always going to stick the the OEM G52
