Old February 26th, 2012, 08:17   #1
stevebrunton
Thumbs up changing headlight bulb
Hi all,
new to the forum, just wondering if anybody has any advice on changing a front headlight bulb on my 2003 vw golf 1.9 tdi , the bulb in question is on the same side as the battery,
any help please?
thanks
stevebrunton is offline   Reply With Quote
Old February 26th, 2012, 09:35   #2
JB05
Fuel Economy: 43/41/40
Take off the battery cover, unclip the rear cover that fits over the rear of the headlight and open it like you would a door. This should free it from the hidden locking tabs. Now you should have access to the clip that secures the head light bulb in its socket, but remove the wiring harness first. It's a tight squeeze, but doable if you take your time. when you go to put the rear cover back on you may want to push down on the plastic underliner that protects the headlight and try to get the locking tabs back in place at a slight angle.
JB05 is offline   Reply With Quote
Old February 26th, 2012, 18:09   #3
blackty
Probably faster to pull bumper, no kidding...Jim
blackty is offline   Reply With Quote
Old February 27th, 2012, 06:57   #4
Powder Hound
Powder Hound's Avatar
Or just pull the battery out of the way.
Like Jim said, pulling the bumper (so you would be able to remove the headlight assembly out of the car) or pulling the battery seems like a lot of extra work, but on the driver's side, there is so little room at the back of the headlight assembly, normal human hands have a very difficult time getting in there and manipulating the bulb since about all you can do is squeeze part of a couple fingers there.
Old February 27th, 2012, 07:50   #5
belome
Fuel Economy: 47'ish
Assuming the golf and jetta are the same... just find someone with small or thin hands and it isn't THAT bad. I'd say less than 10 cuss words and you will have it.
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is offline   Reply With Quote
Old February 27th, 2012, 08:32   #6
JB05
Replacing the high beam is a little more involved with all the wires in the way.
Old February 27th, 2012, 08:45   #7
Seatman
Seatman's Avatar
Fuel Economy: No idea
What a design! I had my bumper off for fitting the engine so went that route for fitting the bulbs, much easier.
Seatman is offline   Reply With Quote
Old February 27th, 2012, 08:50   #8
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy: ☠☭
If just changing the main bulb, it can be done with the headlight & battery in place. I've got fairly large hands and can do it without getting clawed to hell and back. If it's your first time, removing the battery will give you miles of space.
If you post a question, post your solution!
mk4 front wheel bearing | scurvy winter front | VCDS in Chicago, IL USA
You are entitled to your opinions but not your own facts.
scurvy is offline   Reply With Quote
Old March 1st, 2012, 12:26   #9
stevebrunton
Thanks to all.
will try without removing battery!!
thanks again
Old March 1st, 2012, 12:33   #10
diesel4ever
diesel4ever's Avatar
Fuel Economy: 4.2/4.8/5.5
I have done it quite few times. Now I just remove the battery. It takes only two extra minutes and it saves lot of frustration and your knuckles.
2004 Jetta TDI Sport, KERMA Tune, VNT17 Turbo, 505,000km
2004 Jetta (hers), KERMA tune (otherwise stock), auto, 365,000km.
diesel4ever is offline   Reply With Quote
Old March 1st, 2012, 12:37   #11
Lex4TDI4Life
Lex4TDI4Life's Avatar
x2
Just change both sides at once and get some practice in the passenger's side first
2001 Golf TDI 5 spd
RC2, Bosch T4-764 injectors, OMI, SBC Stg 2 Clutch, Koni FSDs, TT LCA Bushings, The Mystery Bar, Dieselgeek Panzer Plate, Elephant Hose, DG Race Pipe, Autometer Cobalt Boost Gauge, Boostvalve,Fumoto Valve, Mufflerectomy, Scangauge II
Lex4TDI4Life is online now   Reply With Quote
Old March 1st, 2012, 18:28   #12
JayT
Originally Posted by Lex4TDI4Life View Post
x2
Yes! If you have one out, you should also change the other. Start with the passenger side then tackle the driver side. I have big hands, you can do it pretty easy if you just remove the battery cover.
JayT
2013 Beetle TDI, tint, Scangauge, Winpower HID headlights
2003 Golf TDI 4-door GLS, Rocketchip stage 2, Boostvalve, Scangauge, LED city lights, euroswitch, Panzer skid plate - SOLD
JayT is offline   Reply With Quote
Old March 2nd, 2012, 17:03   #13
tdiluke1977
TDI(s): golf gls
hey,thank God you dont have to do one on a beetle. That is "FUN"
tdiluke1977 is offline   Reply With Quote
Old March 2nd, 2012, 19:28   #14
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy: ☠☭
Agreed! If by '"FUN" ' you mean 'ridiculously easy'.
It takes what, about 47 seconds and zero tools to pull the entire headlight assembly out of the car...? Another minute and a half and you can have the bulb changed and headlight ready to go back in the car.
Being generous, it shouldn't take you more than 15 minutes to change both headlights the first time.
Old March 2nd, 2012, 20:25   #15
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 3.3 Mi/kWh
That's if the cam / lock rings work properly
-J
Present:
2018 Tesla Model 3 DM. 50,000 miles.
2014 Cadillac ELR. 38,000 miles.
2013 Fiat 500e. 32,000 miles.
Past:
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG. Sold to JDSwann's Brother.
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
headlight bulb changing? USdan VW MKIV-A4 TDIs (VE and PD) 2 February 12th, 2004 04:33
Try changing the left headlight bulb!!! surfTDI VW MKIV-A4 TDIs (VE and PD) 18 December 23rd, 2001 15:14
Changing Headlight Bulb Hurri VW MKIV-A4 TDIs (VE and PD) 10 February 9th, 2001 16:06
Changing a NB headlight bulb. BUG*PWR VW MKIV-A4 TDIs (VE and PD) 6 February 4th, 2000 08:46
Changing a NB headlight bulb. BUG*PWR TDI Maintenance 1 February 3rd, 2000 13:23
© 1996 - 2020, All Rights Reserved
Page generated in 0.18237 seconds with 11 queries
[Output: 128.20 Kb. compressed to 107.13 Kb. by saving 21.07 Kb. (16.44%)]
