Go Back   TDIClub Forums > Picture Gallery/Specs of Members' TDIs > Other TDI/Diesel Picture Gallery
Other TDI/Diesel Picture Gallery Do you have a TDI or Diesel not listed above? If so write a message here describing it and insert a picture if you have one. If you don't have one on the computer, email me and I'll give you my address and I'll scan it for you. If you need web space for it, email me as well. Please make a short yet descriptive title for your vehicle.
Old February 5th, 2017, 04:41   #91
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
Putting 3mm oversize valves is almost impossible because you have to increase valve seats a lot and there is not much room left. Sounds too optimistic to be true.
You might wanna check dimensions you offered above because are totally wrong
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old February 6th, 2017, 05:44   #92
xjay1337
Hi shortysclimbin
Thanks for the post. Many of the issues we are aware of and have already sorted.
Gearbox supports will be done when I eventually get around to switching to a lower mileage gearbox and fit an LSD.
I have not had swirl flaps since originally fitting the gtb kit. Had no issues without them.
Hopefully starting the teardown soon, just finalising some parts.
Hybrid VKLR, BSR Ported Head, BSR Valve Springs, BSR CP3, 395hp 660nm Built and mapped by Bobby Singh , THS IC, Revo/Forge Custom Intake, Mocal Oil Cooler, 3 Eurojet TBE, AKS Quickshifter, Recaro Pole Positions, Schroth 4 point harnesses, Rear seat removal, R bumper, Carbon Fibre GT24 Bonnet, VWR Spoiler, OZ 18x9 Et43, AM DB9 front brakes, Audi S3 rears, Polar FIS, Hertz Audio
xjay1337 is offline   Reply With Quote
Old February 6th, 2017, 06:11   #93
Rub87
Originally Posted by shortysclimbin View Post
Two years ago I ran into the same issues. I actually sold my performance cams, ported, head, dual valve springs, and custom valves last year to a guy in the usa.
Some helpful info maybe:
1) the v6 3.0l TDI CR motors have valves that are about 3mm larger in diameter than oem and same dimensions. they are also sodium filled! I'd suggest running those and just changing the slope angle and valve seat angles on them to fit your needs.
2) the oem intake valve ports split the air and have a very very aggressive reflow swirl built into one of the intakes for low RPM swirl and emissions. Removal of that will drastically help higher RPM but may mean more emissions on lower RPMs. Since you have a good tuner who isn't minding to tinker with new things, (unlike our USA tuners). I'd suggest you keep the intake flapper valves and use the controls to flow more at lower RPM through the single swirl valves that are like the MK4 VE heads. Those intake tracks I'd suggest to only clean them up and worry about the valve seat angles at first! By doing this you will drive a large volume of air at lower rpm to the swirl ports and you can take the old swirl ports and create them into straight feed valves like gas cars for higher RPM. Watch your flow ratios though to make sure you don't kill the swirl and 80% intake to exhaust flow ratio.
3) The cams which have been tested as drop in were used on stock heads. I suspect the flow ports in the head design are actually the limiting factors. Cams on top of a good port job may drastically increase your power potential at higher rpm if you can keep your fuel pressures up in the rail.
4) with the CP3 we were still seeing some fuel rail pressure drops. This was resolved by replacing the stock engine bay electric fuel pump with a heavy duty diesel one that the flows 3 times more pressure.
5) watch that transmission 4/5 gear spread. at the ~390ftlb these manuals have a tendency to walk the gears apart on the 02S transmissions. you might want to get that brace in there if it isn't there already.
Id be happy to hear valve pn and engine code from this v6 engine with 3mm bigger valves. Last time I checked valves where larger, but less than one mm
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old February 6th, 2017, 10:48   #94
Macradiators.com
Exactly Ruben, 0.7mm more , not worth the trouble i think.
CP3 Upgrade
Old February 6th, 2017, 11:51   #95
BleachedBora
BleachedBora's Avatar
Love the new cluster, excellent build!
-BB
BleachedBora is offline   Reply With Quote
Old February 19th, 2017, 08:20   #96
turbobrick240
turbobrick240's Avatar
You kept the auxiliary fuel pump with the cp3? I don't know if that was a good idea.
Old February 19th, 2017, 10:40   #97
YukonLT
Veteran Member - TDIClub Enthusiast
YukonLT's Avatar
Fuel Economy: Good
I was wondering the same thing...
YukonLT is offline   Reply With Quote
Old February 19th, 2017, 12:26   #98
Rub87
depends one th eflavour of cp3. with some it is not adviseable to run positive pressure to fuel inlet, and definately not in the amount that a stock cp4 liftpump provides.
reason for this that some cp3 have the case pressure relief back to inlet, and some to the outlet. if its to the inlet, the case pressure will rise 1:1 with feed pressure and this will make the metering valve flow very different as what the will believe it flows.
Old April 10th, 2017, 04:12   #99
xjay1337
-BB
Thanks for checking in
Finishing the rebuild of my CR170 with ported head. Many thanks as always to Bobby.
I would literally be stuck without him, and it's so nice to have someone who actively wants you to push things further and works to such a high and consistent quality.
Here is the original head.
I've owned it since 100k miles, and been running 2.4 bar boost and for around 50k. Lots of track and drag use.
Been ran on Millers 5w40 or 10w50 CFS NT and changed at least every 10k.
It's now sitting on 180k miles
20170409_204248 by Fat Bear Photography, on Flickr
Valves, no build up to speak of.
20170409_204300 by Fat Bear Photography, on Flickr
Very happy to see the condition of the original head. These are good solid engines.
I will be able to share further news with you all soon.
Old April 16th, 2017, 03:17   #100
xjay1337
We have finished the rebuild of the engine and we are very happy with the results.
2017-04-16_09-46-10 by Fat Bear Photography, on Flickr
IMG_20170415_212828_762 by Fat Bear Photography, on Flickr
This has been an awful lot of work which without Bobby would not have been possible.
We have many custom fabricated parts for this build.
BSR ported head, bsr custom valve springs, bsr cp3 pump, custom injectors, all engine software and engine build done by Bobby.
We are very very happy with this result. EGTs under 900 at WOT. Still making over 300bhp at 5200rpm.
Old April 16th, 2017, 05:56   #101
Rub87
Looking awesome! Will you take it to the strip?
Any reason why you didnt move battery to the trunk? Would be first I would do for a track car
Old April 16th, 2017, 10:41   #102
mickyTDI
mickyTDI's Avatar
Very nice results! What was the engine like after 180k Pistons/bores etc?
2017 VW Passat 2.0 BiTDI 288.4bhp CUAA
mickyTDI is offline   Reply With Quote
Old April 16th, 2017, 16:52   #103
ATR
ATR's Avatar
Wow! Those are some fantastic results
Drivers Wanted
-2011 Golf TDI 6MT = gone but not forgotten!
-2017 Golf GTI Sport 6MT
***Official maintenance schedule for your VW [PDFs inside]***
ATR is offline   Reply With Quote
Old April 18th, 2017, 03:40   #104
Bobby Singh
Bobby Singh's Avatar
TDI(s): Audi 3.0 TDI
Looking good Jay
1/4 mile should be interesting
BSR
Audi A4 3.0TDI B8 - 505hp/980nm...
3.0TDI S200v hybrid (470hp) kit for sale
http://forums.tdiclub.com/showthread.php?t=492614
Bobby Singh is offline   Reply With Quote
Old April 18th, 2017, 05:00   #105
xjay1337
Thanks you sir
We are going to the strip this weekend as long as weather is good.
(So far it is).
Battery relocation is something I may look into now as I have another car as a daily.
Engine was fine, very good condition. A few parts had started to show their age (aux belt tensioner etc) but mechanically good. I had money aside to buy a low mileage engine but it was not needed.
Thank you!! We are very happy. I still can't believe how scary it is when it comes on boost lol.
Many thanks for following along
VW updates the Scirocco BeetleGo General VW Discussion 5 February 17th, 2014 06:20
VW Scirocco andyd68 Other TDI/Diesel Picture Gallery 20 November 25th, 2011 12:37
Fifth Gear - VW Scirocco &REY General Automotive 3 September 16th, 2008 03:44
Old school VW diesel into 86 Scirocco? cujet TDI Conversions 16 April 5th, 2008 23:52
2008 VW Scirocco Confirmed tommyt TDI News/Tech 25 August 28th, 2006 15:48
Page generated in 0.16738 seconds with 13 queries
[Output: 141.33 Kb. compressed to 119.40 Kb. by saving 21.93 Kb. (15.52%)]
