gmcjetpilot
I posted a few threads recently, installing new shocks and struts, new rear sway bar, and alignment results from commercial rack. I did not get the answer I wanted on rear alignment adjustment. I am posting to help benefit any what my research found, who cares to search these forums or google. There are two eccentric bolts one on upper trans ling and one on lower transverse link. The eccentrics are at the subframe. The upper will effect mostly camber. The lower toe. It is my opinion that adjusting either will have some effect on the other, camber or toe and vice verse (as well as caster). I think camber has less effect on toe. I can't see the toe not effecting camber. How much I don't know. I have a digital level. I am going to try and measure it before and after toe adjustment. Since I am putting on sway bar I see no reason to take a stab on making a small adjustment. If you have any input let me know.
