trevormarsh
New here. 2005.5 1.9 BRM TDI and the car will start and run for 3 seconds then shut off. A garage where I broke down checked the exhaust for obstructions. None. MAF was checked & functioning as it should. Fuel is present. VAG did not show any problems. They found the only way to get the car running was to close the EGR valve and disconnect EGR Electronically. With it closed the car starts and runs fine. Got the car home and cleaned intake including the EGR. Put it back together and the same problem. Starts and runs for seconds. Pull EGR, close valve and unplug and it runs fine. Is EGR Normally open on start? I checked Shutter valve and it is open on start and closes to shut down. The valve does not move manually at all.
Monday I will replace the fuel filter and see what happens.
Please any suggestions.
