coalminer16
Now is a good time to replace all the rubber hoses, Inspect axles for damage and wear. Clean engine bay (grease), Replace motor mounts, clutch and tranny seals, etc. That why you have a trouble free car for many miles without naging nickel and dime problems that arise with older cars. Tie rods, struts, ball joints. Inspect radiator and heater core (they are pretty cheap to replace if needed). Inspect all wiring as well in the engine, check brakes, front and rear wheel bearings. Good luck.
