Hey Everyone,
Newb here as you can tell. Always wanted a TDI and finally got one last fall (2004 Jetta Wagon w/BEW). Has been a great car but shortly after buying it I realized the turbo was probably going bad (or so i thought). It sounded pretty sweet, like a mini semi truck, really loud, but i could also hear rubbing and the occasional squeal when to much load was placed. I'm a conservative driver for the most part. I drove it as little as possible until last week when i could finally afford a rebuild. I had Ron's turbo service in Salt Lake rebuild it. He cleaned everything, repainted it, internals weren't reusable so he did new cartridge. To my knowledge everything but the housing and VNT is new. He made it look great, I read on his ebay and google reviews many people have had great reliability with his rebuilds.
ANYWAY. I installed the turbo last week. I used all new gaskets crush rings etc. I used anti-seize where appropriate and some blue (serviceable) threadlock where appropriate. I tried to make sure i did the best work I could because it is a lot of work (to me) to get that thing (the turbo) out. When I had everything hooked up i primed the turbo with oil before starting and after primed I let it run for several minutes and watched for leaks, there were none. When priming I know it had oil because i left the flare fitting on the turbo a little loose and oil shot out of it with just turning the car over, no idle.
The car ran great for 3 days until i got on the freeway one day and couldn't hold more than 70 mph. It felt like i had the A/C on with a trailer behind me. I was in a canyon and there was a grade. CEL came on, as soon as i pulled it I found 3 codes, one was "turbo charger boost control position sensor circuit low" and the other two were" turbo charger under/overboost." I can figure I'm not making boost since I have no power. I cleared the CEL and limped it home and noticed a thumping noise. After checking for exhaust leaks (none) i pulled the charged air pipe off the turbo outlet and noticed a pulse coming from it, as if one piston is leaking exhaust stroke into it. I can feel this pulse in the airbox if I just put my hand on it. I have read on TDIClub that the EGR's on these cars are somewhat tedious. I'm trying to address my pulse issue first as i feel it it worse than just not making boost. Any suggestions/diagnostics I can try? Sorry for the Novel, just trying to be thorough.
