racecartom
03 ALH Jetta, 448k, 5spd. I have gotten the P0216 code and only glow plug codes. The code showed up when I started getting a stumbling problem at very low throttle positions. I have read a few threads on here and am trying to avoid removing the IP and changing the AS since I did a timing belt about 15k ago. I also had to replace the cap and quantity adjuster seals on the pump about 5k ago. I got the quantity back to 3.2. I have unplugged the MAF and only had one stumble in the last 2 days of driving. Stumbles seem to have disappeared. Is this possibly a MAF issue (MAF has about 50k on it). Can the AS be changed without removing the entire IP?
Thank you for the help.
