I've been following the bible; DanG144's AC troubleshooting guide.
I didn't have a way to check duty cycle at the G65 sensor but I did get 3.1VDC and 5.1VAC so I believe that's enough to call it working.
I'm at step 5 and I believe I've found the problem but want to be sure. The document states that I should see 9-9.5v at the compressor coil. Unplugged I'm getting 12.19 which puzzles me. When I plug back into the coil and pierce the wire I get the same 12.19. Weird.
I checked the resistance to the coil with the connector unplugged and got 1 which I believe shows an open (dead) coil correct?
Just wanted to be certain that voltage wasn't an issue and that I've narrowed it down to the coil before I order one.
Thanks Dan and all!
Thanks Dan and all!
