Ok, here's the po'boy special... There aren't $300 worth of tools, it's compact and the whole kit fits into the smallest Priority Mail box. I've yet to have USPS lose one of those... at least, not yet...
Here is how the crank hold goes on...
All you need to do is bring the engine to TDC, clean out the bolt holes at the corners of the block put the four bolts in finger tight. Use a 3/4" breaker bar,cause if you use 1/2", it will be a 'broken' bar.
I also include the hylomar sealant; keeping in line with the po'boy concept. If you buy the tube, it's $12.50. You use enough of a blob to cover a nickel and the next time you use the tube, it's cured through and through.
Just use what you need and return the tube and counterhold set back to me for the next po'boy.
You could make the tools, but it'd take you an hour. $20 and the shipping,you get the crank bolt, the seal and you borrow the tools and a tube of sealant. Use what you need of the sealant (more does not make it better) and return the tube with my counterhold tools and bolts.
The ALH seal and bolt set are pictured. The AHU/ 1Z set have different seal and bolt. I've got them too.
Tighten the ALH crank bolt to 88 ft lbs + 1/4 turn
Tighten the AHU crank bolt to 66 ft lbs + 1/4 turn
Tighten the flange bolts to 7 ft lbs. No more then that...
