Jetta_Pilot
- Joined
- Apr 14, 2005
- Location
- West Hill, Ont.
- TDI
- 2015 Passat Highline TDI Candy White (SEL Premium) long gone 2002 Jetta TDI
I have to start out by saying here in Mexico I drive my car very seldomly because of the ULSD requirement. So far only LSD here, not the drugs!
About four weeks ago my car would not start. Put a Ctek charger (max 3.5 amp charge) on it and overnight charged the battery. Yesterday I had to use my car and drove for one hour to another city. A few times under way instead of D6 I was shifting down to D3 or D4 for higher revs and try to force a regen cycle. When I got to Walmart I shut the car off, my hand was quicker than my eye. I noticed my Scangauge was showing EGT and CAT at over 1,200°F. Restarted and waited til the temps had come down to about 400°F. Came back about 30 minutes later, no problem starting. Drove about 15 minutes and parked again. I did hear the fans running as I left which has happened before. When I got back about 15 minutes later, the engine wouldn't turn over.
Called a friend who suggested I buy booster cables, which I did, the only ones available. Said he would be there in 20 minutes. In the meantime some kind friendly Mexicans also had cables. But using theirs or my new cables did not start the car. I suggested to use both, their and my cables doubled up in parallel but they said no and indicated the battery would go "boom". Both, their and my cables were getting warm used one or the other. Obviously not enough amperage.
My friend came long, also with skinny cables, no start. I again suggested to double up on the cables which we did, the engine turned over and started.
I know this is along story to ask if the OEM battery is sealed or can it be opened to see if the fluid levels are low? Can the fluid evaporate sitting here in the heat? According to my Scangauge I am charging at 13.7 volts, this was last night with lights and AC on.
After charging the battery overnight and the charger disconnected the voltage at the terminals reads 11.6 volt. Since it's OEM the indicator window on the battery shows black for good. Yellow would be a bad battery.
Any suggestions at all? If I have to replace the battery, what amp value should it be?
RM
RM
