ritsco
I have read a few threads and I am still trying to diagnose my problem.
2006 Mk IV Golf, 09A Auto. Just did the solenoids and the trans is shifting and acting fine and also put on new brake pads. Struts and shocks good condition. There is no play in the front end or the drive shafts and I just checked the balance on all four tires. No bad vibrations at the steering wheel either.
Anyway, I have a noise coming from the front end (exact location TBD) and it sounds like a bunch of marbles in a box that is being rotated. The noise is most evident at low (crawl) speeds, both in drive and in reverse. If I put the trans in neutral and go slow in either forward or reverse, the noise is still present. I jacked the car up and put her in drive, but really didn't get much noise.
Also, when on the throttle and accelerating, the noise diminishes to almost nothing. When I let off the gas, it gets loud.
I am thinking either wheel bearings or CV joints. Anyone care to offer up an opinion.
Thank you.
Thank you.
