jagris
Hi everyone! First off, I'm new here and this is my first post, though I have been reading through the threads for the past couple of weeks trying to catch myself up on these engines.
About me: Fairly mechanically inclined, I've done all of the maintenance on all of my cars, from complete engine rebuilds to changing the oil. This is my first diesel car.
The Car: I went to an estate junk sale and while poking around I discovered a 2006 Jetta TDI 5spd covered in blackberry bushes with 130k miles on it. The tabs are from 2015, so it's been there quite a while. The son and wife of the owner said the car "stopped working" and they parked it. I was intrigued, so I went back out with some fresh diesel, chopped away the bushes, pulled the fuel filter, drained out the old gas, poured in a little fresh, threw in a new battery and it started right up. Revving the engine the oil light and alarm would sound. I bought the car for $100 and towed it home.
So Far: Once I got the car home I changed the oil and filter (it had oil but it was black as coal and very thin, no metal in it). Started it up and at rpm the oil light still came on. I took off the engine plastics, poked around and discovered the pressure sensor wire had come loose. Plugged it in and and no more oil warning!
The Plan: It has 3/4 tank of diesel in it, so I'm going to pump that out and get as much of the fuel out of the hoses as possible. I'm going disconnect the hoses at the filter and run some pure diesel purge through it. All together, oil change and filter, fuel drain with fresh diesel, purge, fuel filter, cabin air filter, and an engine air filter. While testing for the alarm the only codes it seems to be showing me are a yellow steering wheel and a airbag fault code. So I'll dig into those codes. After that the plan is to find out why (if it wasn't the wire) it was parked. If it's really bad, sell it. If it's something I can fix pretty affordably, it could be my new daily.
The Question: Is there anything else I should do to resurrect this thing? Replace the glow plugs? Replace the orings on the injectors?
Thank you!
Thank you!
