Nope nothing wrong with that oil. CJ4 synthetic, if, it is the diesel Gold.
Typical Specifications and Performance Data:
SAE GRADE 5W-40
API Gravity 33.7
Viscosity Index 170
Viscosity, cSt @ 40 °C 86
Viscosity, cSt @ 100 °C 14.2
Pour point, °C -45
TBN 10
Flash COC ,°F 445
Cold Crank Simulator cP @-20°C 6,300
The above specs are very similar to the CJ4 shell T6 which has been used successfully.
The cast steel cams can be successful if they meet the minimum surface finish and hardness quality control standards as stated by the manufacture and should not wear followers in 30,000 miles.
The billet cams may or may not have better quality control. I was under the impresion the billet cams are turned from billets and not drop forgings. You would expect it to be better since it is more expensive to produce( batch production).
It should be noted that cast steel cams are likely poured and flame hardened
and then ground continuously and could be harder to maintain grinding finish standards.
If a proper "installation", along with a 20 minute no load breakin was done and oil changed and then changed at 500 miles, then I would be inclined to blame manufacture quality control.
That's interesting. What is the difference with the 505.01 oil?
Basically I'm coming to the conclusion that, yes, I was not using 505.01 oil, but that may not have been the cause of the cam wearing out.
Mine is a billet cam with the black lifters. My dad was the one who installed it, so I'm not sure about whether it was broken in correctly, I think it was correctly installed though.
I know that at one point, my sister had taken it to a local diesel shop, where the guy was supposed to set the timing. When it came back, it was hard starting. Ended up he had installed the timing belt one notch off, and tried to turn the cam pulley in the slots to make up for it. I took the timing belt off and reinstalled it with the correct tools,and then it worked. (I decided that guy wasn't going to do any mechanical work on my cars... )
So, it ran a bit off time for a while, and had extended crank. Then in the last few weeks, the tandem pump was going out, so if it sat very long, it would take a long time to start.
Would the extended crank cause more cam wear?
Also last oil change, I did a BG engine flush, though that's supposed to be better on your engine... I've sent my oil in for analysis each oil change for a while, and nothing has been abnormal.
I may contact id parts and see what their warranty policy is on the cam, though I'm thinking I'll sell the car, with a cam or not. I got a B5.5 Passat wagon to replace it with.
Sent from my KYOCERA-E6790 using Tapatalk
