Hi there.
Recently had a post about losing a coolant, and the dealer said I drive 3k+miles a month it is normal. I don't believe this. I should not refill 2-3 oz a week.
After reading some posts about bad heater cores, I realized my air vents do not blow the same warm air, the ones in the center above radio unit is very weak. So I set up an appointment for next week requesting heator core replacement.
This post may help others with same problem as I was looking for a reason why I lost coolant for months.
According to some other posts, this is a cronic problem for B7 TDI.
- Window fogging,
-Coolant loss are some of the symptoms.
Could other forum members share how was their experiences with heater cores, how many times did they replace and what are the symptoms they encountered?
I hope will be an informative post for all members, as we see many new posts about heater cores.
Thanks!
- Window fogging,
Thanks!
