bob141
Apologies if I missed searching in archive threads:
A4 BEW 2004 Jetta Wagon TDI.
Been seeing Power Steering fluid leak at the Tie Rod Boots. Clamps had come loose (Mechanic used plastic zip ties). I applied metal clamps to remedy, I thought.
Now outer end driver boot on tie rod shows split and leaks. Why, given installed in 2015, new tie rods with boots and my originals lasted from 2004 till 2015.
So occured to me, I have bigger problem. If fluid in Tie Rod Boot, is it really the Steering Rack leaking? It's original (222k miles). Researching my Robert Bentley, but can't fnd any clues there.
If just the boot is issue, don't suppose they make a "split" boot to install and save taking off tie rod. Had such for old VW Beetle (65) on CV joints.
Maybe I need another mechanic.
Thanks.
Thanks.
