Old November 6th, 2018, 15:16   #1
Asbury030
TDI(s): 02 Jetta
Default Leaking Clutch master cylinder???
Is this what I'm dealing with here? I have not noticed any issues with my clutch as of now.
Asbury030 is offline   Reply With Quote
Old November 6th, 2018, 15:49   #2
Asbury030
TDI(s): 02 Jetta
Would this be a good website to go by to replace the cylinder?
https://www.pelicanparts.com/techart...eplacement.htm
Old November 8th, 2018, 06:39   #3
Asbury030
TDI(s): 02 Jetta
It's leaking right under the clutch pedal on to my floor mat. I'm assuming it is a bad clutch master cylinder... so I ordered a new gasket and new cylinder. Going to hopefully have it fixed Sunday morning.
Old November 8th, 2018, 06:52   #4
burn_your_money
You are correct. Mine just did that last month.
If you don't disconnect the clutch line at the slave, the master is self bleeding. Just slowly pump the pedal about 50 times and it will bleed the air out. No need to mess around with bleeders and 2 people.
burn_your_money is offline   Reply With Quote
Master Cylinder, Slave Cylinder, or Clutch Failure?? mwc360 VW MKV-A5 Golf/Jettas 7 December 3rd, 2015 05:00
Brake master cylinder/clutch master cylinder? dweisel VW MKIII-A3/B4 TDIs 16 July 2nd, 2015 20:09
Clutch master cylinder or Slave cylinder, Which is FAIL ? Mcgink VW MKIII-A3/B4 TDIs 22 November 26th, 2014 14:34
Clutch master cylinder and Slave clutch cylinder repair kit? surfbus VW MKIII-A3/B4 TDIs 3 October 19th, 2012 23:39
Urgent clutch master cylinder leaking srmichi TDI 101 9 June 21st, 2011 15:56
Page generated in 0.11731 seconds with 11 queries
[Output: 61.36 Kb. compressed to 55.04 Kb. by saving 6.33 Kb. (10.31%)]
