Old October 9th, 2017, 18:51   #1
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Default Master cylinder ESP sensor leak
Just replaced my master cylinder... while bleeding the top of the system, I got a leak coming from the ESP sensor... when removing it from the old master cylinder, there was no sealant present... is any supposed to be there on the threads? (yes, it's on as tight as I can get it...)
Thanks,
Yuri
Quando omni flunkus moritati
ymz is offline   Reply With Quote
Old October 10th, 2017, 10:27   #2
UhOh
UhOh's Avatar
Yuri, does Bentley cover replacing the sensor?
Old October 10th, 2017, 11:59   #3
ymz
Nothing specific... ETKA doesn't show any "O" ring or sealant... I don't see any reason for it leaking... unless the sealing surface or threads on the new Master Cylinder are out of spec...
Yuri
Old October 10th, 2017, 12:08   #4
UhOh
UhOh's Avatar
Oh, man, hopefully Brian will come along and provide some guidance. I hate brake fluid (when it's not contained)!
Old October 10th, 2017, 13:12   #5
ymz
I'll wait for some suggestions, but one possible "solution" - put the old master cylinder back in... I did notice that when I removed it there was no rubber "O" ring (not really, just a gasket) between the booster and the master cylinder... (this had been replaced by a hack shop far from here - with used parts...) Perhaps that was why the brakes were wonky...
Yuri.
Old October 11th, 2017, 20:03   #6
where2
where2's Avatar
Is this a spot where this is supposed to be a copper crush washer between the sensor and the master cylinder?
Typically at the pressures the brake system runs at, things get sealed by flares. Being a sensor, I could see it more like an oil pressure sensor using a copper crush washer to limit fluid migration.
'19 e-Golf SE (w/ DAP)
'13 Jetta SportWagen TDI, 6MT (4 Wife) 55k and counting...
'06 Jetta_TDI Pkg_1 5spd (wife's DD for 169k, RIP totaled)
'04 Jetta_TDI_Wagon_GL 5spd (4 daily) Got Miles... 232k!
'90 Corrado_G60 Pkg_2 5spd (4 fun) Supercharged and half the fuel economy of a TDI!
where2 is offline   Reply With Quote
Old October 11th, 2017, 23:06   #7
ymz
No crush washer indicated... put in the old master cylinder... no leak... I don't see them having changed the physical dimensions of the threading...
Master Cylinder, Slave Cylinder, or Clutch Failure?? mwc360 VW MKV-A5 Golf/Jettas 7 December 3rd, 2015 05:00
Brake master cylinder/clutch master cylinder? dweisel VW MKIII-A3/B4 TDIs 16 July 2nd, 2015 20:09
Clutch master cylinder or Slave cylinder, Which is FAIL ? Mcgink VW MKIII-A3/B4 TDIs 22 November 26th, 2014 14:34
ESP or not? Master Brake Cylinder pdaves TDI 101 3 June 13th, 2008 10:35
Master Cylinder Replacement on 2005 Golf TDI with ESP Question scottab VW MKIV-A4 TDIs (VE and PD) 1 April 28th, 2007 14:56
Page generated in 0.15834 seconds with 11 queries
[Output: 80.56 Kb. compressed to 69.76 Kb. by saving 10.80 Kb. (13.41%)]
