I have a new SMIC with 2.5 lower plumbing. rocketchip stage 3, VR6 Clutch, 11mm pump with lift pump. Kerma TDI Long Runner intake manifold, 2.5 DP - str8 pipe. PP520 nozzles, bilstein suspension with coil overs. Running stock gt1749v turbo. I will be putting a stage 2 or 3 cam in, with head studs and would like to do something with the turbo eventually here. Maybe try to hybridize it somehow to squeeze 200hp (which is my goal for this car) out of it, or upgrade to gt1749vb which I could make 17/22 or go for 1726 instead (daily driver so like the faster spool). Not really sure where I'm at with HP currently, guessing like 160. Gunna jump on the dyno this fall.
With that said. I would like to upgrade to a 3 bar MAP. I read that u can't just slap it in and be done. You have to adjust some sort of tuning. Can someone explain this a little for me? Keep in mind I have a rocketchip, and I can't seem to get them to reply to me. Basically I want to know if I can buy some software or something and adjust what I need to make the 3 bar work. Thanks in advance.
Sent from my SAMSUNG-SM-N920A using Tapatalk
