Go Back   TDIClub Forums > Classifieds/For Sale/Wanted > Private TDI Items for Sale/Wanted
Private TDI Items for Sale/Wanted VW TDI/Diesel related items for wanted and for sale by private individuals. Group Buys and commercial posts should be in the "Vendor & GroupBuy" section.
Old January 16th, 2015, 14:27   #1
msantram
msantram's Avatar
Default Gauging Interest: Polar FIS+
I am gauging interest to see if members would be interested buying a Polar FIS+ device new shipped for $265. If there is enough interest, I will register as a vendor and post up a formal ad within the group buys section.
Moderators: I just want to test the waters before doing all of the vendor registration work. Hope this is okay.
msantram is offline   Reply With Quote
Old January 16th, 2015, 14:45   #2
JSWTDI09
JSWTDI09's Avatar
That is a great price! I paid well over $300 for mine last year (about $325 shipped, IIRC). Needless to say, I'm not interested in another one, but I would be surprised if you can't sell them fairly easily at that price. Good Luck!
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old January 16th, 2015, 15:10   #3
midntdi
Fuel Economy: 40-50 mpg
Will there be a version for the MkVII golfs?
Torden: http://forums.tdiclub.com/showthread.php?t=418613
Lyn:2015 Night Blue Golf TDI
midntdi is offline   Reply With Quote
Old January 17th, 2015, 08:42   #4
msantram
msantram's Avatar
thx @don! your posts were helpful to me in making the decision to look at this device again.
I will check to see @midntdi
Old January 18th, 2015, 14:22   #5
Mike in Anchorage
Mike in Anchorage's Avatar
I like the pun. And I'm interested if this will work in an '09 JSW. Subscribed to thread.
~ I'm selfish, impatient and a little insecure. I make mistakes, I am out of control and at times hard to handle. But if you can't handle me at my worst, then you sure as hell don't deserve me at my best. Marilyn Monroe
2015 Tornado Red Golf TDI Sportwagen SE, new on 2 SEP 2017, DSG, big sunroof. Lovin it!
Mike in Anchorage is offline   Reply With Quote
Old January 18th, 2015, 15:07   #6
JSWTDI09
JSWTDI09's Avatar
Yes, it works perfectly in my '09 JSW. Here are a few (crappy cell phone) pics.
When you install (or update) the firmware, you install either the file for a red MFD or a white one (2006-2009 or 2010+). Separate firmware is required because the communications protocol (with the instrument panel) is different between a MkV and a MKVI (red or white MFD display).
Have Fun!
Don
P.S. Ignore the negative boost reading in the first pic. I had a configuration selection wrong. It works correctly now.
Old January 18th, 2015, 15:18   #7
JSWTDI09
JSWTDI09's Avatar
That is a good question. It is not currently listed as a supported vehicle at auto-Polar's website. Your best chance of getting any real answer would be to post this question on the Auto-Polar forum here: http://www.auto-polar.com/forum/forum.php
Have Fun!
Don
Old January 30th, 2015, 20:12   #8
JaredC01
JaredC01's Avatar
Add me to the list of wanters...
|DG Sigma 6 SSK||BFI Schwarz Knob||PolarFIS Advanced||Frost Heater|
|Pioneer 4000NEX||JL Audio 700/5v2||Polk Audio MM6501 x2||JL Audio 12w3v3-2|
JaredC01 is offline   Reply With Quote
Old January 31st, 2015, 14:24   #9
GreenLantern_TDI
GreenLantern_TDI's Avatar
Fuel Economy: Mid 40s
Me Too.
How difficult is the install?
2015 Golf SEL. Malone DSG Tune. H6 AGM East Penn Battery. Frost Heater. Ares Skid Plate. Fumoto Valve. PentoIII.
GreenLantern_TDI is offline   Reply With Quote
Old January 31st, 2015, 14:50   #10
mishkaya
Originally Posted by GreenLantern_TDI View Post
Me Too.
Install is not bad. There is a write-up on the forums somewhere.
'06 Jetta 5MT, '14 JSW 6MT, '10 JSW 6MT
mishkaya is offline   Reply With Quote
Old January 31st, 2015, 14:56   #11
JSWTDI09
JSWTDI09's Avatar
Me Too.
In theory, it's really easy. You unplug a plug and stick the wire that comes with the device in between the plug and socket you just unplugged.
In practice, it's a little bit harder. First you have to lay on the floor under the steering wheel (with your butt hanging out the door), you have to remove a few torx screws and remove an under dash plastic cover. Then you have to reach up above the brake pedal and find the plug (not too hard) and unplug it. This is not as easy as it sounds because it usually takes 2 hands, one to pull the plug out and one to push the little locking tab in. There is not a lot of room down there if you have long arms. Then the hardest part is plugging in the connector on the Polar harness. They say it is the same connector VW uses (from the same manufacturer) and I have no reason to doubt their word, but many people (including me) have had problems getting that plug fully inserted into the CAN gateway. It is a tight fit and it can require a lot of force. Make sure that the connector firmly snaps into place. If this connector is not fully plugged in a whole lot of stuff doesn't work (including your car). If this happens to you, you better have access to VCDS so you can clear all of the fault codes it will generate. Mine now works perfectly, and I love it, but here's more about my installation adventure if you are interested. http://forums.tdiclub.com/showpost.p...&postcount=107
Have Fun!
Don
Old January 31st, 2015, 16:05   #12
GreenLantern_TDI
Default Polar Fis +
Great install instructions.
So were all clear is this group buy for the
Polar Fis+ (PF02) or the
Polar Fis+ advanced (PF03) ?
Old January 31st, 2015, 16:12   #13
JSWTDI09
JSWTDI09's Avatar
I am pretty that the only one they currently sell is the PF03. I believe that the PF02 was just an older model - which they still support with updates. The Auto-Polar website does not list the PF02 as a current product for sale, they only talk about the latest (KESSY enabled) FIS+ Advanced.
Have Fun!
Don
Old January 31st, 2015, 16:17   #14
msantram
msantram's Avatar
Good news everyone, the group buy is a GO! If you are interested, please PM me with your Name & Email address.
The group buy will be through Les of German Diesel Motorwerks. Everyone knows him and his excellent work. He's a vendor here, so all payments will be through him. I will be sending a PM to everyone who said they were interested.
As Don has so aptly written, the Polar FIS+ unit Model PF03, will work in our SportWagens. If you have any questions about the unit and capabilities / compatibility, please read up on http://www.polarteam.net/en/home/65-...-advanced.html
Thx everyone!
Old January 31st, 2015, 16:20   #15
mishkaya
Great news! I was starting to wonder if this was ever going to go through...
Auto Polar FIS+ Advance (MBV in the MFD) OEM+ Hypermile VW Passat Family (NMS and B7) TDIs (2012+) 359 December 8th, 2018 16:29
Polar Fis Advanced Lasse.s Upgrades (non TDI Engine related) 20 May 20th, 2018 21:14
Polar-FIS : integrated alternative to scangauge? Diesl OBD Scanners 25 December 28th, 2017 16:25
Gauging Interest in TDI ZACK VW MKV-A5 Golf/Jettas 15 December 18th, 2011 10:50
Gauging interest tires and rims bardie Ontario 8 October 15th, 2011 04:23
Page generated in 0.17946 seconds with 11 queries
[Output: 132.85 Kb. compressed to 110.67 Kb. by saving 22.18 Kb. (16.69%)]
